Over 1.124.000 registered users (EN+CZ).
CAD tip # 7714:
Question
If you program a macro or an add-on module for Revit, using either the integrated VSTA environment, or on of the Visual Studio .Net programming languages, sooner or later you will need a "magic" constant to multiply the size units.
Revit uses feet as internal units in its BIM database. You don't neccessarily see these units in the Revit UI as a user (if you use the metric settings) but you definitely need them as a programmer - and convert the internal values in some API functions. For these conversions you may need two constants:
Const MeterToFeet As Double = 3.2808399 Const FeetToMeter As Double = 0.3048or - in millimeters:
Const MmToFeet As Double = 0.0032808399 Const FeetToMm As Double = 304.8
Revit
7.1.2011
11354×
this tip shared by ARKANCE experts applies to: Revit ·
