CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2347
CAD tip CAD tip # 8093:
Missing 2D views, VIEWBASE in AutoCAD Architecture 2012.
A - answer The CUI panel "2D views" and the commands VIEWBASE, VIEWPROJ, VIEWEDIT, VIEWUPDATE and VIEWSTD are not available in the AEC versions of AutoCAD 2012.
Despite the Help lists them (a known defect), these commands are intended primarly for mechanical drawings (and processing 3D models from MCAD software) and so they are not available in AutoCAD Architecture 2012, AutoCAD Map 3D 2012 or AutoCAD Civil 3D 2012.
ADT2012Map2012Civil2012
21.7.2011    1035x
Comments   Tell a friend
Tip 8518:2D views and sections of a 3D solid in AutoCAD.
Tip 7954:AutoCAD 2012: Generate 2D drawing views from 3D models.
How to select lines of a given length? « | » Purple or cyan frame around a Revit view.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
