Cesky English Deutsch
Login/Register:
 Visitors: 5411
CAD tip CAD tip # 9822:
Modified fillet along obstacles - sharp edges.
A - answer If you need to modify (flow) fillet of a body along a sharp edge, use the option "Roll along sharp edges" in extended options of the Fillet dialog.
Compare filleting without and with this option:
Zaobleni, fillet
Inventor
12.5.2014    2893×
Comments   Tell a friend
applies to: Inventor ·
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
Tip 8528:Import AutoCAD 3D DWG files into Inventor.
Tip 6537:How to model a 3D thread (screw) in AutoCAD?
Tip 5208:Automatic feature recognition on imported 3D models.
DrGrid - parametric grid for AutoCAD drawings. « | » Set units/scale for STEP export from AutoCAD.
