CAD tip # 8672:
| Question | CAD % platform category |
applies to: Inventor 2013 · | |||||||||
| See also: | |
| Tip 9228: | How to create a knurled surface in Inventor? |
| Tip 8996: | Material-based hatch patterns in Inventor section views. |
| Tip 8862: | Error on publishing iPart to your library in CC (external dependencies). |
| Tip 8800: | How to set diamond plate material in Inventor? |
| Tip 8102: | Infinite library of rendering textures - Substance. |
How to reverse the orientation of a line or polyline?
Cannot sign DWG drawing - error: "A digital ID is required" « | » How to add sizes to Inventor's involute splining.
Featuring: Add .CIT raster format support to AutoCAD and Map and Civil 3D CITin
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]](../common/3d_cs2_t.gif)
CADforum Home
CAD Discussion
Tips & Tricks
Downloads
CAD Blocks
CAD Videos
Web Links
SW Development
Search
