CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2447
CAD tip CAD tip # 8465:
Objects get selected while moving mouse cursor.
A - answer AutoCAD drawing objects may be highlighted ("selected") when you move cursor over them. If you don't use an accelerated graphics card or you have a slow computer, you may want to suppress this highlighting setting.
Set the SELECTIONPREVIEW variable to 0 or 2. Or use the setting on the Selection tab in the Options dialog, the "Selection preview" section - the "Visual effects..." button.
ACAD2012ACAD2008
13.2.2012    834x
Comments   Tell a friend
applies to: AutoCAD 2012 · AutoCAD 2008 ·
Tip 8640:Text formatting codes in MText objects.
Tip 8458:How to set the Select objects mode for the Hatch command?
Tip 8412:Selecting multiple objects in a particular order.
Tip 8289:Autodesk Navisworks keyboard shortcuts.
Tip 8187:Suppress object selection highlighting when no AutoCAD command is active.
How to display full document path in Inventor title bar? « | » Unusual AutoCAD linetypes - from Microstation RSC files.
