CAD tip CAD tip # 8782:
Question
Since AutoCAD version 2013, the new variable FRAMESELECTION controls, whether a frame of images, underlays and clipped xrefs should be selected:
  • 0 - hidden frames cannot be selected
  • 1 - hidden frames can be selected
Set FRAMESELECTION to 0 for pre-Rel.2013 behaviour.
The variable PREVIEWFILTER may block frame display while selecting but the frame can be still selected.
With the combinaton of the variable IMAGEFRAME set to 0 you can setup that images cannot be selected while all other entities "above" them can be selected.
To select objects except images you can also use the LISP expression:
(ssget '((0 . "~IMAGE")))
ACADMapCivilADT
27.8.2012   16271×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Map 3D · Civil 3D · AutoCAD Architecture ·
Tip 12361:Seamlessly connected images by irregular clipping in AutoCAD (or LT).
Tip 9363:How to hide the frame of a wipeout, embedded DWF or DGN?
Tip 3900:How to hide the frame of a raster image?
Tip 2494:Cannot select (and move) raster images inserted in a drawing.
Back    All CAD Tips
Categ:
