The CAM application Autodesk Inventor HSM (2015, build 2.0.0 and newer) contains the following postprocessors. These are control and definition JavaScript files (.cps) stored in the folder C:\Users\Public\Documents\Autodesk\Inventor HSM\Posts\. All postprocessors are fully customizable, plus you can add your own.
A similar postprocessor set is available also in the CAD/CAM application Autodesk Fusion 360 (former CAM360) - see the subfolder Applications\CAM360\Data\Posts or its cloud repository.
Machine/Control system name | Postprocessor | NC-file extension |
Acu-Rite MILLPWR 2 | acurite millpwr 2.cps | .nc |
Acu-Rite MILLPWR 3 | acurite millpwr 3.cps | .nc |
Generic Acramatic | acramatic.cps | .nc |
Generic Anderson-Fanuc | anderson.cps | .nc |
Generic Andronic | andronic.cps | .asc |
Generic Anilam Conversational | anilam conversational.cps | .m |
Generic Belotti | belotti.cps | .nc |
Generic Biemmepi | biemmepi.cps | .iso |
Generic BostoMatic | bostomatic.cps | .nc |
Generic Bridgeport | bridgeport.cps | .nc |
Generic Centroid | centroid.cps | .nc |
Common ISO 4343 APT | apt.cps | .apt |
Generic Denford | denford.cps | .fnc |
Generic Dialog 112 | dialog 112.cps | .ncl |
Dumper | dump.cps | .dmp |
DynaPath Delta | dynapath.cps | .txt |
Generic Enhanced Machine Controller (EMC) | emc.cps | .ngc |
Generic EZ-Trak Conversional | eztrak conversional.cps | .pgm |
Generic Fadal | fadal.cps | .nc |
Generic FAGOR | fagor.cps | .pim |
Generic FANUC - Inverse Time and A-axis | fanuc - inverse time - a-axis.cps | .nc |
Generic FANUC (with G91) | fanuc incremental.cps | .nc |
Generic FANUC Turning | fanuc turning.cps | .nc |
Generic FANUC with subprograms | fanuc with subprograms.cps | .nc |
Generic FANUC | fanuc.cps | .nc |
FlexiCAM | flexicam.cps | .gc |
Generative Machining APT | generative-machining.cps | .apt |
Generic GPlus | gplus.cps | .nc |
Generic GSK 928MA | gskcnc.cps | .nc |
Generic HAAS - Inverse Time and A-axis | haas - inverse time - a-axis.cps | .nc |
Generic HAAS Turning | haas turning.cps | .nc |
Generic HAAS A-Axis | haas with a-axis.cps | .nc |
Generic HAAS | haas.cps | .nc |
Generic Heidenhain ISO | heidenhain iso.cps | .i |
Generic Heidenhain/MANUALplus Turning | heidenhain turning.cps | .nc |
Generic Heidenhain | heidenhain.cps | .h |
Generic HURCO | hurco.cps | .hnc |
Generic Intelitek | intelitek.cps | .nc |
Generic ISEL Intermediate | isel.cps | .ncp |
Generic Mach2Mill | mach2mill.cps | .tap |
Generic Mazak | mazak.cps | .eia |
MAZATROL Fusion 640M EIA/ISO | mazatrol fusion640m.cps | .nc |
Generic Mektronix | mektronix.cps | .cnc |
Generic MELDAS | meldas.cps | .nc |
Generic MillPlus | millplus.cps | .nc |
Generic Milltronics | milltronics.cps | . |
Minimal Heidenhain | minimal.cps | .h |
Generic Mitsubishi | mitsubishi.cps | .nc |
MultiCam HPGL | multicam hpgl.cps | .plt |
MultiCam ISO | multicam.cps | .cnc |
Generic NUM | num.cps | .nc |
Generic OKUMA | okuma.cps | .min |
Operation Sheet CSV | operation-sheet-csv.cps | .csv |
Operation Sheet | operation-sheet.cps | .html |
Generic Opticut | opticut.cps | .nc |
Generic OSAI | osai.cps | .nc |
Generic ProtoTRAK GCD | prototrak.cps | .gcd |
Generic Roeders RMS6 | roeders rms6.cps | .tap |
Generic Roland ISO | roland iso.cps | .nc |
RS-274D | rs274.cps | .nc |
Generic SCM-Prisma 110 | scm.cps | .xxl |
Generic Seicos | seicos.cps | .nc |
Generic Selca | selca.cps | .nc |
Heidenhain TNC 407 | heidenhain 407.cps | .h |
Setup Sheet Excel 2007 | setup-sheet-excel-2007.cps | .xlsx |
Setup Sheet Excel | setup-sheet-excel.cps | .xls |
Setup Sheet | setup-sheet.cps | .html |
ShopBot OpenSBP | shopbot.cps | .sbp |
Siemens SINUMERIK 802D | siemens-802d.cps | .mpf |
Siemens SINUMERIK 840D | siemens-840d.cps | .mpf |
Generic Tekna | tekna.cps | .ppg |
Generic Thermwood | thermwood.cps | .nc |
Generic TinyG | tinyg.cps | .gcode |
Tool Sheet CSV | tool-sheet-csv.cps | .csv |
Tool Sheet | tool-sheet.cps | .html |
Validator | validating.cps | .chk |
Generic WinCNC | wincnc.cps | .tap |
XML Cutter Location Data | xml.cps | .tp.xml |
Generic YASNAC | yasnac.cps | .nc |
Example of a part of the definition code from the postprocessor control file .cps:
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
writeMachine: true, // write machine
writeTools: true, // writes the tools
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
overrideLengthOffset: -1, // overrides the length offset is positive by adding this number to the tool number (-1 for disabled)
overrideDiameterOffset: -1, // overrides the diameter offset is positive by adding this number to the tool number (-1 for disabled)
o8: false, // specifies 8-digit program number
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
showNotes: false // specifies that operation notes should be output.
