CAD tip CAD tip # 7910:
Question
Even in AutoCAD version 2010, 2011 and 2012 you can publish DWF files in the old text format DWF (version 00.42) compatible with the original DWF viewing component WHIP!.
Use the command PLOTTERMANAGER to create a new PC3 file, where you select as the output device "DWF Classic (R14)", or "DWF ePlot (WHIP!3.1 compatible version)".
DWF Classic (CZ)
Then select this newly defined device to plot to DWF.
DWF
12.4.2011   13086×
this tip shared by ARKANCE experts applies to: DWF/Design Review ·
Tip 4513:Negative (inverse) viewing of CAD and PDF files.
Tip 2027:What are the advantages and disadvantages of using ePlot DWF format vs. PDF?
Tip 1571:How to view DWF files on other than Windows platforms?
Tip 1370:How to make a PDF file from your drawing?
Tip 1319:How to display a given view from DWF file?
Back    All CAD Tips
Categ:
