CAD tip CAD tip # 7839:
Question
The CADstudio QRcodeConverter for Inventor inserts QR Code symbols into Inventor drawings.
Just enter the text to be encoded and it will be converted to a sketched symbol into the current drawing sheet in Inventor. You can also use iProperties to encode dynamic texts - like the Part number and Material.
QR code
QRcodeConverter is a part of a larger add-on software for Inventor 2010 and higher, the Be.Smart T4I (former "X-Tools") or its "LT" version - available on Autodesk Apps.
The free utility QRcodeConverter can be downloaded from here. Read the Readme file.
Inventor2011Inventor2010
6.3.2011   14750×
this tip shared by ARKANCE experts applies to: Inventor 2011 · Inventor 2010 ·
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14500:Autodesk starts using OTP (One-Time Passcode) verification on user accounts.
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Tip 13703:How to generate a dynamic QR code or Data Matrix on an Inventor drawing?
Tip 7667:Automatically generated QR codes for DWG drawings.
Back    All CAD Tips
Categ:
