Cesky English Deutsch
Login/Register:
 Visitors: 4823
CAD tip CAD tip # 11481:
Quickly repeat last command in Fusion 360 (like Enter in AutoCAD)
A - answer Even Autodesk Fusion 360 offers a method for quick repeating a command, performing the same action over and over - similar to pressing the Enter or space key in AutoCAD.
  Any command in Fusion can be repeated using a mouse gesture leading to the function Repeat in the circular marking menu. Perform a right-click with your mouse and drag it up (either holding the right button or with a separate click) to repeat the last command. This gesture leads to the function Repeat in all commands with a context (right-click) menu.
  Similarly to this gesture "Up" you can anytime use the gesture "Left" to perform Undo, or the gesture "Right" to perform the Redo function.
Fusion360
17.6.2017    2926×
Comments   Tell a friend
applies to: Fusion360 ·
Tip 11652:How to make a part in a Fusion 360 design partially visible (semitransparent)?
Tip 11600:How to rename a project in BIM 360 or Fusion Team?
Tip 11320:How to find volume, mass or surface area of a component in Fusion 360?
Tip 10524:Panel titles are not shown in Revit ribbon.
Tip 10329:Easily share your Fusion 360 design.
Adding selected numbers in drawing texts - counting numbers (GrSelNum). « | » "Assertion failed" error when launching AutoCAD.
LogOff 2006 More info
