Cesky English Deutsch
Login/Register:
 Visitors: 5888
CAD tip CAD tip # 9731:
Revit filled region doesn't mask the underlying geometry.
A - answer In one Revit view, the filled regions do not cover (mask) the lines "under". Why?
This is most probably caused by the selected visual style. In the Wireframe style, masking regions do not cover the underlying geometry with filled areas. Switch to Hidden Lines.
RevitRevitLT
12.3.2014    4013×
Comments   Tell a friend
applies to: Revit · RevitLT ·
Tip 4097:Filled region in Revit 7 does not cover the underlying geometry.
What are the files .fmsh, .fwiz, .fins and similar? « | » Do you know the commands GIRAFFE or GRAVEL in AutoCAD?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
