Over 1.124.000 registered users (EN+CZ).
CAD tip # 8412:
Question
If you need to select multiple objects in a particular order (e.g. for exporting texts in TRANS), you can use the Fence option of the "Select objects:" prompt.
With the Fence option you can draw a virtual line (polyline) which strikes through the objects to be selected. The start and direction of the individual segments of this line will then define the specific order in which the DWG objects are selected.
"EE" "DD" "CC" "BB" "AA" "FF" "GG" "HH" "II" "JJ" "KK"
ACAD
12.1.2012
8026×
this tip shared by ARKANCE experts applies to: AutoCAD ·
