Cesky English Deutsch
Login/Register:
 Visitors: 7796
CAD tip CAD tip # 9378:
Somethings wrong here, the light's still present...
A - answer No, this is not a citation from a B-Grade sci-fi movie (and the Light of Zarta from MIB II isn't it either). This is a genuine (but rare) AutoCAD error message.
Can appear when trying to delete a light definition - e.g. from the "Lights in Model" palette. It may indicate that the DWG drawing is corrupted. Try to recover it.
ACAD
8.8.2013    3244×
Comments   Tell a friend
applies to: AutoCAD ·
Tip 11729:Select objects by annotation scale.
Tip 11664:Which AutoCAD commands do exist also in the commandline (non-dialog) dashed version?
Tip 11581:How to compare changes between two versions of a Revit BIM project?
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Tip 11389:Readability of annotations, white halo on AutoCAD texts.
How to change cursor color in the Inventor text editing window? « | » How to import 3D CAD data into Autodesk FormIt?
Link your AutoCAD texts with Excel tables/sheets. Export. Change. Import.
Try DwgText 2015 More info
