CAD tip CAD tip # 7289:
Question
The help system in AutoCAD 2011 uses the online help on Autodesk web site. If you want to switch (toggle) the help function back to the local files in the folder C:\Program Files\Autodesk\AutoCAD 2011\Help, change the setting in the AutoCAD Options.
In the Options dialog (OPTIONS, A > Options), on the System tab, uncheck the option "Use online help from Autodesk website when available" in the Help pane.
The current setting of this option is trored in the undocumented variable WBHELPONLINE.
ACAD2011ACLT2011ADT2011Civil2011
29.3.2010   14849×
this tip shared by ARKANCE experts applies to: AutoCAD 2011 · AutoCAD LT 2011 · AutoCAD Architecture 2011 · Civil 3D 2011 ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14978:Integrated issue management in Revit 2027.
Tip 14969:Examples of AI prompts and the challenges of using the Autodesk Assistant AI feature for analyzing and generating CAD geometry in AutoCAD and Fusion.
Tip 14957:Controlling Navisworks from the runstring.
Tip 14879:Quick insertion of concrete column shoes in Revit.
Back    All CAD Tips
Categ:
