Cesky English Deutsch
Login/Register:
 Visitors: 8149
CAD tip CAD tip # 9692:
Unfoldable spiral-helix sheet metal in Inventor.
A - answer With a spiral curve and an iLogic macro you can create a spiral-helix sheet metal (worm, screw) in Inventor and then unfold this 3D part. The procedure is illustrated in this video:
(co-author of this tip: Wili)
An alternative way for irregular helixes Tip 9300 (in Czech).
Inventor
5.2.2014    5546×
Comments   Tell a friend
applies to: Inventor ·
Tip 10708:Modeling compression injection screw for molding machine.
Tip 10138:Dimensioning a curve length or distance between two points on a curve.
Tip 9038:Double helix - twisted pair in Inventor
Tip 8832:Bent coil (helix) in Inventor.
Tip 6650:Break curve at all listed distances (stations).
Random object colors in 3ds Max. « | » Starting Fabrication CADmep 2014 in another AutoCAD - desktop icon.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
