Cesky English Deutsch
Login/Register:
 Visitors: 4973
CAD tip CAD tip # 9340:
Using iLogic to parse IPT filename and populate iProperties.
A - answer Assume that you have your IPT files named like PARTname-REVx.IPT (e.g. tracker9864-rev6-7-2013.ipt) and you want to automatically assign the part iProperties "Description" and "Revision" to the name and revision parsed from the file name.
You can use the following iLogic macro to do this. This macro uses regular expressions and their parenthesis groups to parse the filename and get the first and second part of the string delimited by "-" (in the first case) or parse the filename string by a fixed number of characters - 7 and 3 (in the second case, commented out):
docname=ThisDoc.FileName(False) 'e.g. "tracker9864-rev6-7-2013"
Dim matches As System.Text.RegularExpressions.MatchCollection
Dim match As System.Text.RegularExpressions.Match
Dim groups As System.Text.RegularExpressions.GroupCollection
matches = System.Text.RegularExpressions.Regex.Matches(docname, "\b([^-]+)-*([^-]+).*\b") '*****-****: $1/$2 = tracker9864/rev6
'matches = System.Text.RegularExpressions.Regex.Matches(docname, "\b(.{7})(.{3}).*\b") 'NNNNNNRRR*: $1/$2 = tracker/9864
If matches.count>0 Then
 For Each match In matches
  groups = match.Groups ' parenthesis 1 and 2
  iProperties.Value("Project", "Revision Number") = groups.item(2).Value
  iProperties.Value("Project", "Description") = groups.item(1).Value
  MsgBox("iProperties set to " & groups.item(1).Value & " and " & groups.item(2).Value)
 Next
 Else
 MsgBox("No match!")
End If
Similarly you can modify the BOM, drawing texts, etc. Change the regular expression as you need.
Inventor
16.7.2013    5810×
Comments   Tell a friend
applies to: Inventor ·
Tip 11854:iLogic error in Inventor 2019: invocation of constructor threw an exception
Tip 11801:What is the difference between ThisDoc.Document and ThisApplication.ActiveDocument in iLogic?
Tip 11732:How to sort BOM or parts list by part number in Inventor? (iLogic)
Tip 11542:How to reset the top browser node name back to the file name?
Tip 11244:Labels with incrementing numbers - assembly with numbered labels for laser cutting.
How to include hydrostatic pressure to my FEM simulations? « | » When moving one entity, the adjacent entity moves too.
