Cesky English Deutsch
Login/Register:
 Visitors: 4734
CAD tip CAD tip # 9674:
Vault: Check-in drawings along with the models.
A - answer If you want to check-in (save) your drawings together with checked-in models of an Inventor part or assembly, use the respective button for related files in the middle of the Vault Check-in dialog. You can setup what type of files should be searched (presentations, IDW/DWG drawings) and where they should be searched.
Included file types:
The resulting check-in of models and drawings:
VaultInventor
28.1.2014    3365×
Comments   Tell a friend
applies to: Vault · Inventor ·
Which product do I need to view DWF and other CAD files online? « | » How to display multiple types of parts lists in Inventor drawings?
Link your AutoCAD texts with Excel tables/sheets. Export. Change. Import.
Try DwgText 2015 More info
