Cesky English Deutsch
Login/Register:
 Visitors: 8003
CAD tip CAD tip # 9927:
What is the maximum size of a polyface mesh in AutoCAD?
A - answer AutoCAD can create and process polyface mesh surfaces (PFACEMESH, AcDbPolyFaceMesh, the command PFACE) up to the size of 32767 vertices.
The newer mesh-type object (sub-division MESH, AcDbSubDMesh, the command MESH) can contain up to 16.7 million faces.
ACAD
1.8.2014    2266×
Comments   Tell a friend
applies to: AutoCAD ·
Tip 11726:Loading 3D models in the OBJ file format to AutoCAD.
Tip 11590:How to replace a 3D mesh model with a grid structure?
Tip 11575:What is the Linked account in your Autodesk Account profile?
Tip 11387:How to edit large STL files in Fusion 360?
Tip 11311:Importing STL files directly into AutoCAD.
Editing history of Revit RVT files. « | » Text linked with Inventor drawing view.
