Cesky English Deutsch
Login/Register:
 Visitors: 4475
CAD tip CAD tip # 9339:
When moving one entity, the adjacent entity moves too.
A - answer When you e.g. move a block placed on a line, the line may move along with the block -- most probably there is a constraint between these two entities (objects). This constraint may have been created manually or rather automatically. Too many constraints may slow down your drawing. The ar indicated by a "double flag" icon when you hover on an entity.
You can remove the adverse constraint with the command DELCONSTRAINT. If you want to avoid creating automatic constraints on related objects, switch off this behaviour with the variable CONSTRAINTINFER (set to 0), or press the key combination Ctrl+Shift+I (see also the first icon on AutoCAD status bar).
ACADADTACADMCivilMap
16.7.2013    3500×
Comments   Tell a friend
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11896:How to drive dyn.block parameters or constraints from Excel?
Tip 11761:Parametric constraints between 3D objects in AutoCAD.
Tip 11497:Automatic grouping of drawing objects.
Tip 11354:Animate dyn.block parameters and dim.constraints in AutoCAD DWGs.
Using iLogic to parse IPT filename and populate iProperties. « | » Dimensional value or resultant geometry is inconsistent with existing configuration.
