CAD tip CAD tip # 8011:
Question
Whenever you close the Block Editor (BEDIT), AutoCAD performs a zoom to an area close to the drawing origin (0,0) and you have to find again your original view. How to get rid of this behaviour?
Switch off the variable UCSFOLLOW (i.e. set it to 0). This variable controls (among others) also the zooming when terminating the block edit mode.
ACADACLTADTMapCivil
31.5.2011   17508×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D ·
Tip 13620:How to quickly rotate the view by 90° in AutoCAD LT?
Tip 13514:Why does the Power dimensioning command zoom my drawing?
Tip 11847:Automatic UCS aligned with the current View (UCSauto switch).
Tip 9954:Selecting hatch borders performs zoom out.
Tip 5713:How to switch off UCSFOLLOW in all viewports of all layouts?
Back    All CAD Tips
Categ:
