CAD tip CAD tip # 9220:
Question
By default, Inventor 2014 loads IAM assemblies in standard (full) mode and uses the Express mode only on demand (see Assemble > Productivity, or the checkbox in Open > Options...). But if an assembly contains more than 500 parts (referenced files) and the Express mode is available, this assembly is opened directly in the Express mode. This behaviour and the number of files can be set in the Application options on the Assembly tab:
Assembly options in Inventor 2014 (CZ)
If you have your IAM assembly opened in the fast Express mode (will be indicated as shown below) and you need one of those editing functions which require the full mode, you can use the button "Load Full" (available in all ribbon tabs).
Load Full (CZ)
Inventor2014
23.4.2013   11242×
this tip shared by ARKANCE experts applies to: Inventor 2014 ·
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14634:Physical units conversion tool in an Inventor palette.
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14204:How to draw a parabola in Autodesk Fusion (or other 2D/3D curves).
Tip 14098:How to use arc length parameter in Inventor sketch?
Back    All CAD Tips
Categ:
