CAD/BIM Library of blocks Electrical
Free CAD+BIM Blocks, Models, Symbols and Details |
Free CAD and BIM blocks library - content for AutoCAD, AutoCAD LT, Revit, Inventor, Fusion 360 and other 2D and 3D CAD applications by Autodesk. CAD blocks and files can be downloaded in the formats DWG, RFA, IPT, F3D. You can exchange useful blocks and symbols with other CAD and BIM users. See popular blocks and top brands.
Insert new block (you have to be logged in)
Electrical
Category 4 - Electrical :
Total found 1490 records
Pult operátoraPult_operatora.dwgOvládací pult cat: _Other DWG2013 Downloaded: 75x Size 738,3kB • from 21.03.2024 Uploader: Romík • Author: Roman Molex39301040 v1Molex39301040_v1.f3dConnector Molex 39301040 cat: Connectors Fusion360 Downloaded: 6x Size 297kB • from 26.02.2024 Uploader: SergejV • Manufacturer: Molex Molex39301060 v1Molex39301060_v1.f3dConnector Molex 39301060 cat: Connectors Fusion360 Downloaded: 2x Size 405,7kB • from 26.02.2024 Uploader: SergejV • Manufacturer: Molex Nixie tube ZM1040Nixie__tube_ZM1040.iptiPart - Nixie tube - digits controlled by table cat: Electronic parts Inventor part IPT2020 Downloaded: 9x Size 1,42MB • from 07.02.2024 Uploader: Sivák • Author: Sivák 4mm Red Banana Female Socket Jack Mount Connectors4mm_Red_Banana_Female_Socket_Jack_Mount_Con.f3d4mm red banana female socket jack - mount connector cat: Connectors Fusion360 Downloaded: 5x Size 200kB • from 04.02.2024 Uploader: StevenTr Dynamic Elec. Plan SymbolsDyn._Elec.Symbols.dwgDynamic Elec. Plan Symbols cat: _Other DWG2018 Downloaded: 314x Size 188,4kB • from 29.01.2024 Uploader: IntegrityDrafting • Author: Chris Lowe Socket 14 pin 7_62 mmSocket_14_pin_7_62_mm.ipt14-pin socket cat: Connectors Inventor part Downloaded: 4x Size 358kB • from 05.12.2023 Uploader: Sivák • Author: Sivák Socket 16 pin 7_62 mmSocket_16_pin_7_62_mm.iptObjímka pre IO 16 pin cat: Connectors Inventor part Downloaded: 11x Size 371kB • from 05.12.2023 Uploader: Sivák • Author: Sivák Socket 18 pin 7_62 mmSocket_18_pin_7_62_mm.iptObjímka pre IO 18 pin cat: Connectors Inventor part Downloaded: 12x Size 390kB • from 05.12.2023 Uploader: Sivák • Author: Sivák Digitron-nixie tube 1040Digitron-nixie_tube_ZM1040.ipt3D model digitronu cat: Electronic parts Inventor part Downloaded: 33x Size 1,14MB • from 26.11.2023 Uploader: Sivák • Author: Sivák |
CAD blocks: elektrische libraries dwg blocks bloques blocos blocchi blocco blocs blöcke family families symbols details parts models modellen geometry elements entourage cell cells drawing bibliotheque theme category collections content kostenlos insert scale landscaping
We appreciate all your comments and input to the functionality of CAD Catalog, to the category tree, etc.
Please report possible bugs to webmaster@cadstudio.cz.
Nous apprécions tous vos commentaires et suggestions sur la fonctionnalité du catalogue CAO, sur l'arborescence des catégories, etc ainsi que sur les bogues éventuellement rencontrés. Merci de transmettre vos remarques a webmaster@cadstudio.cz.
Want to download the whole library? Télécharger l'ensemble du catalogue?
You can download all CAD blocks directly from your AutoCAD, without logins and any limitations.
See the add-on application Block Catalog for AutoCAD 2013 and higher and the add-on application BIM-Families (now in Revit Tools) for Revit 2015 and higher.
CAD blocks can be downloaded and used for your own personal or company design use only. Any distribution of the Catalog content (to other catalogs, web download, CD/DVD media, etc.) is prohibited - see Terms of use.
The DWG-version problem (not valid file, invalid file, drawing not valid, cannot open) can be solved by the Tip 2869.
See also block-statistics and the latest 100 blocks.
