  <title>CAD F&#243;rum : AutoCAD 2012 - Zamrzá při startu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : AutoCAD 2012 - Zamrzá při startu]]></description>
  <pubDate>Tue, 09 Jun 2026 15:18:18 +0000</pubDate>
  <lastBuildDate>Thu, 10 May 2012 11:03:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=15073</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu : E&#353;te sk&#250;ste toto: http://usa....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70241&amp;title=autocad-2012-zamrza-pri-startu#70241</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 11:03<br /><br /><P>Ešte skúste toto:</P><DIV><a href="http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4366058&linkID=9240617" target="_blank" rel="nofollow">http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&amp;id=4366058&amp;linkID=9240617</A></DIV><DIV>prípadne:</DIV><DIV><a href="http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10244411&linkID=9240617" target="_blank" rel="nofollow">http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&amp;id=10244411&amp;linkID=9240617</A></DIV>]]>
   <pubDate>Thu, 10 May 2012 11:03:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70241&amp;title=autocad-2012-zamrza-pri-startu#70241</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :    Defter napsal(a):  Je&#353;t&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70240&amp;title=autocad-2012-zamrza-pri-startu#70240</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=14517">rychetsky</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 10:51<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Defter" alt="Původně odeslal(a) Defter" style="vertical-align: text-bottom;" /> <strong>Defter napsal(a):</strong><br /><br />Ještě taková drobnost, zkusil jste před startem CADu přehodit výchozí tiskárnu například na PDFCreator... Programy jako CAD nebo Office obvykle při startu kontrolují nastavení výchozí tiskárny a podle toho rovnou připravují rozvržení zobrazení...</td></tr></table><div>&nbsp;</div><div>To bych jí musel přehodit před vypnutím PC, abych to měl při novém spuštění již jako výchozí.</div><div>To by nejspíš pomohlo, ale pak mi samozřejmě nastává problém při tisku, když budu chtít vytisknout email nebo word tak budu muset měnit tiskárnu z PDFCeatoru na UTAX.</div><div>Takže mi bohužel nezbude nic jiného, než se modlit aby nám nějaká vyšší moc seslala nový printserver. A do té doby budu muset ručně restartovat print spooler.</div><div>Zajímavé je, že to nedělá pokaždé. Občas CAD zapnu bez problémů a občas zamrzne...je to tak 1:3.</div>]]>
   <pubDate>Thu, 10 May 2012 10:51:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70240&amp;title=autocad-2012-zamrza-pri-startu#70240</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu : Vyzer&#225; to na driver. Tie&#382; pou&#382;&#237;vam...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70239&amp;title=autocad-2012-zamrza-pri-startu#70239</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 10:47<br /><br />Vyzerá to na driver. Tiež používam HP Universal Printing.<DIV>Asi to s tým nesúvisí, ale máte SP na AutoCAD?</DIV>]]>
   <pubDate>Thu, 10 May 2012 10:47:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70239&amp;title=autocad-2012-zamrza-pri-startu#70239</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :   Je&#353;t&#283; takov&#225; drobnost, zkusil...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70235&amp;title=autocad-2012-zamrza-pri-startu#70235</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=964">Defter</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 09:41<br /><br />Ještě taková drobnost, zkusil jste před startem CADu přehodit výchozí tiskárnu například na PDFCreator... Programy jako CAD nebo Office obvykle při startu kontrolují nastavení výchozí tiskárny a podle toho rovnou připravují rozvržení zobrazení...]]>
   <pubDate>Thu, 10 May 2012 09:41:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70235&amp;title=autocad-2012-zamrza-pri-startu#70235</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu : A nelze tisk&#225;rny p&#345;ipojit p&#345;&#237;mo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70234&amp;title=autocad-2012-zamrza-pri-startu#70234</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 09:34<br /><br />A nelze tiskárny připojit přímo do sítě?<br><br>Jinak i když máte tiskárnu připojený přes printsever, tak máte lokálně nainstalované drivery a ty musí být ty správné pro Váš operační systém. <br>]]>
   <pubDate>Thu, 10 May 2012 09:34:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70234&amp;title=autocad-2012-zamrza-pri-startu#70234</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :   No co se t&#253;&#269;e tiskov&#253;ch driver&#367;,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70233&amp;title=autocad-2012-zamrza-pri-startu#70233</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=14517">rychetsky</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 09:23<br /><br />No co se týče tiskových driverů, tak s tím nic moc neudělám. Protože ve firmě máme nějaký stařičký printserver a obávám se, že příčinou těchto problémů bude on. Nedávno jsme tam s naším ITkem zkoušeli aktualizovat 64bit driver pro naší tiskárnu UTAX a zkončilo to fiaskem <img src="https://www.cadforum.cz/forum/smileys/smiley5.gif" height="17" width="17" border="0" align="absmiddle" alt="C&#111;nfused" />.<div>&nbsp;</div><div>Jinak jsem koukal do toho prohlížeče událostí a našel jsem tam jen 2 chyby.</div><div>&nbsp;</div><div><font color="#000000" size="3" face="Times New Roman"><u></u></font><p style="margin: 0cm 0cm 0pt;" ="Ms&#111;normal"><span style='font-family: "Segoe UI","sans-serif"; font-size: 9pt;'><strong><font face="Arial, Helvetica, sans-serif"><font color="#ff0000">Přičekání na připojení služby hpqwmiex bylo dosaženo časového limitu (30000 ms).<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></font></font></strong></span></p><font color="#ff0000" size="3" face="Arial, Helvetica, sans-serif"><strong><u></u></strong></font><p style="margin: 0cm 0cm 0pt;" ="Ms&#111;normal"><span style='font-family: "Segoe UI","sans-serif"; font-size: 9pt;'><o:p><font color="#ff0000" face="Arial, Helvetica, sans-serif"><strong>&nbsp;</strong></font></o:p></span></p><font color="#ff0000" size="3" face="Arial, Helvetica, sans-serif"><strong></strong></font><p style="margin: 0cm 0cm 0pt;" ="Ms&#111;normal"><strong><font face="Arial, Helvetica, sans-serif"><font color="#ff0000"><span style='font-family: "Segoe UI","sans-serif"; font-size: 9pt;'>Přičekání na odezvu transakce služby Spooler bylo dosaženo časového limitu (30000ms).</span><o:p></o:p></font></font></strong></p><font color="#000000" size="3" face="Times New Roman"></font></div>]]>
   <pubDate>Thu, 10 May 2012 09:23:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70233&amp;title=autocad-2012-zamrza-pri-startu#70233</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu : M&#225;te v&#353;echny drivery pro Va&#353;i...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70231&amp;title=autocad-2012-zamrza-pri-startu#70231</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 08:59<br /><br />Máte všechny drivery pro Vaši verzi Windows? Nemáte náhodou nějaký starší tiskový driver, nebo nějaký pro 32-bit?<br>Co nějaká chybová hláška ve správci počítače (prohlížeč událostí)?<br><br>Pokud nenajdete konkrétní chybu, zkuste odinstalovat všechny tiskárny, stáhnout nové drivery a postupně je instalovat. Nepoužívejte žádný driver pro VISTU!<br>]]>
   <pubDate>Thu, 10 May 2012 08:59:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70231&amp;title=autocad-2012-zamrza-pri-startu#70231</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :    alfred napsal(a):Funguje...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70228&amp;title=autocad-2012-zamrza-pri-startu#70228</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=14517">rychetsky</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 10.kvě.2012 v 08:13<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) alfred" alt="Původně odeslal(a) alfred" style="vertical-align: text-bottom;" /> <strong>alfred napsal(a):</strong><br /><br />Funguje Vám v té zamrzací situaci WORD? Ten si při spouštění kontroluje tiskárny. Možná to dělá AutoCad také.</td></tr></table><div>&nbsp;</div><div>Tak shodou okolností mi CAD opět zamrznul při startu, takže jsem zkusil pustit Word.</div><div>Mám Word 2010 a ten najede bez problému. Takže CAD sice stále visí, ale s Wordem pracovat mohu, ale nemohu tisknout. A když jdu ve Win do sekce zařízení a tiskárny, tak je to prázdné.</div>]]>
   <pubDate>Thu, 10 May 2012 08:13:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70228&amp;title=autocad-2012-zamrza-pri-startu#70228</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :    &amp;#034;WSCommCntr&amp;#034; je...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70219&amp;title=autocad-2012-zamrza-pri-startu#70219</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=14517">rychetsky</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 09.kvě.2012 v 15:27<br /><br /> "WSCommCntr" je trošku jiný příběh <img src="https://www.cadforum.cz/forum/smileys/smiley2.gif" height="17" width="17" border="0" align="absmiddle" alt="Wink" />&nbsp;.<div></div>Ten už jsem řešil někdy u verze 2010. Tohle je čistě problém print spooleru.]]>
   <pubDate>Wed, 09 May 2012 15:27:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70219&amp;title=autocad-2012-zamrza-pri-startu#70219</guid>
   <title><![CDATA[AutoCAD 2012 - Zamrzá při startu :   AutoCAD inicializuje tisk&#225;rny...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70218&amp;title=autocad-2012-zamrza-pri-startu#70218</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 15073<br /><strong>Zasláno:</strong> 09.kvě.2012 v 15:00<br /><br />AutoCAD inicializuje tiskárny jinak než Inventor. Zamrzající print spooler může být způsoben problémem konkrétního tiskového driveru nebo kolizí této služby s antivirovým systémem.]]>
   <pubDate>Wed, 09 May 2012 15:00:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=15073&amp;PID=70218&amp;title=autocad-2012-zamrza-pri-startu#70218</guid>
