   právě nás čte: 4540
Téma uzavřenoUveden hotfix Revit 2020.2.2
Dodáváme produkty Autodesk
Bodů: 21528
Přímý odkaz na tuto zprávu Téma: Uveden hotfix Revit 2020.2.2
    Zasláno: 07.kvě.2020 v 21:57
Byla vydána aktualizace 2020.2.2 pro Revit a Revit LT (2020). Ke stažení na Autodesk Account nebo v Desktop App.
Novinky a opravy:
Software embedded in the update executable:
Revit 2020 - version 20.2.20.31
Autodesk Cloud Models for Revit 2020 - version 20.2.20.31
Personal Accelerator for Revit - version 21.0.11.0
OpenStudio - version 0.1.9
Issues Resolved
Annotation - Dimensions
Fixed an issue when upgrading a model with an incorrect dimension leader style.
Beams, Braces
Fixed an issue that structural framing elements might be incorrect for cloud rendering.
Fabrication - MEP
Fixed an issue that could lead to product instability when dragging to connect open ends of inline fittings.
Fixed an issue with the Optimized Straights feature which was occasionally incorrectly altering the length option from Auto to Value.
Family Editor
Improved stability when using Create Similar with certain families.
File Open/Save Internals
Improved stability when saving a family file from a cloud model after changing the Maximum backups in File Save Options dialog.
Floor
Improved stability when orbiting or editing elements in a 3D view.
gbXML
Fixed an issue that caused exterior wall surfaces to be assigned to a space without a spaceIdRef when exported to gbXML.
Import/Export Other
Updated Revit to use FBX Toolkit version 2020.0.
Licensing
Fixed an issue which caused Revit to become unresponsive.
Link Topography
Fixed an issue where coordinates were changed when the linked topography was reloaded.
MEP Other
Improved stability when editing a family that had been corrupted.
MEP Pipe
Fixed an issue that caused instability when switching views while editing a pipe's diameter.
Reinforcement - Shape Driven Rebar
Improved stability when upgrading a Revit project containing rebar.
Improved stability when editing rebar constraints.
Revit Home
Fixed an issue where the name of the local copy instead central model was displayed on the Recent Files page.
Startup/Shutdown
Removed potential security vulnerability.
User Interface
When an unrecoverable error happens, a clear link from Revit to the self-service support page is provided.
View - Analysis Visualization
Improved the performance of the display of Analysis Visualization entities when more than one set of independent results is added to a view simultaneously.
ViewCube Navigation
Improved stability when click on the navigation bar.
Important Notes
Dynamo for Revit
In some cases Dynamo will not be visible within the Manage tab after 2020.2.2 Hotfix is applied. To restore Dynamo, replace DynamoRevitDS.sig and DynamoRevitVersionSelector.sig the following location: C:\Program Files\Autodesk\Revit 2020\Addins\DynamoForRevit\Revit\
Content
Updated Content for Revit 2020.2 is not included in the patch deliverable and is provided on the Autodesk Knowledge Network, link.
Uninstall
Revit updates cannot be uninstalled to revert Autodesk Revit 2020 to its pre-update state. If you need to remove the update, please uninstall Autodesk Revit 2020 and then reinstall it.
Arkance Systems s.r.o. - www.arkance-systems.cz
(podpora viz hd.cads.cz)
Tip 13151:Kompatibilita produktů Autodesk s Windows 11.
Tip 12208:Revit 2020 se mi nečekaně přepne do režimu prohlížeče.
Tip 9940:Jde do Revitu načíst SKP soubory ze SketchUp 2013, 2018, 2019 či 2020?
Tip 12660:Kde vzít doplňkové moduly pro Revit 2021?
Stránka byla vygenerována za 1,367 sekund.
