   právě nás čte: 135
Téma uzavřenoPowerMill update 2021.0.1
Dodáváme produkty Autodesk
Bodů: 21526
Přímý odkaz na tuto zprávu Téma: PowerMill update 2021.0.1
    Zasláno: 03.čvc.2020 v 16:39
Byl vydán první hotfix pro CAM aplikaci Autodesk PowerMill 2021. K dispozici je na Autodesk Account a opravuje následující problémy:
Toolpaths
A problem has been fixed that could cause excessively long calculation times when using automatic collision avoidance with point redistribution. PMILL-13640
A problem has been fixed that could cause colliding moves to be included in a toolpath without the toolpath being marked as unsafe. PMILL-13724, PMILL-13876, PMILL-13883
A problem has been fixed that could cause a toolpath to be incomplete when using automatic collision checking with a tool assembly that included a shank component entirely within the holder. PMILL-13855
When corner filleting settings are not compatible with other parameters, such as spiral or 5-axis settings, the toolpath is not calculated and an error message is issued. PMILL-12906
Toolpath simulation
Verifying an NC Program again no longer discards simulation issues on connections. PMILL-13696
A problem has been fixed where ViewMill could close unexpectedly when loading a triangulated block. PMILL-13391
Deposition at the start of each additive pass is now shown in stock simulation. PMILL-11776
A problem has been fixed with additive stock simulation that could cause it to miss the first move of some toolpaths. PMILL-13395
Printing
An issue that prevented printing and print preview from working correctly has been fixed. PMILL-13850
Arkance Systems s.r.o. - www.arkance-systems.cz
(podpora viz hd.cads.cz)
Tip 12876:Jak do PowerMill načíst soubory formátu Parasolid 33?
Tip 13051:Jak načíst 3D model z CATIA V5-6R2021 do PowerMill 2022?
Tip 13605:Jak v PowerMill načíst soubory formátu Parasolid 34?
Tip 12888:Editace rodiny v Obsahovém centru končí chybou Publikování není úspěšné.
Tip 12728:Bezplatný prohlížeč CAM projektů PowerMill a FeatureCAM.
Tip 13100:Mohu provozovat AutoCAD na MacOS 12 Monterey?
Stránka byla vygenerována za 0,512 sekund.
