pavelstyl
Přihlášen: 06.říj.2004 Lokalita: Czech Republic Používám: AutoCAD Mech 2025, SolidEdgeE 2025 Stav: Offline Bodů: 229 |
Téma: Instalace AutoCADu 2012Zasláno: 07.lis.2011 v 09:09 |
obrátil se na mě kolega s problémem instalace AutoCADu. Je student a stáhnul si studentský AutoCAD 2012 a Civil. Ani jeden software mu nejde nainstalovat. Obě instalace končí chybou, níže přikládám log. Operační systém je Win7 32bit, AutoCAD je 32bit. Zkoušel odinstalovat NET framework 4.0, restart a spustit instalaci AutoCADu znovu. Též chyba. Nějaký nápad? Děkuji Pavel Štyl 2011/11/5:14:57:15 Tomas Sedlak HOME-PC === Setup started on HOME-PC by Tomas Sedlak === 2011/11/5:14:57:15 Tomas Sedlak HOME-PC Launch 2011/11/5:14:57:20 Tomas Sedlak HOME-PC PageOpen LaunchDialog 2011/11/5:14:57:30 Tomas Sedlak HOME-PC PageOpen LicenseDialog 2011/11/5:14:58:05 Tomas Sedlak HOME-PC PageOpen ProductInfoDialog 2011/11/5:14:58:29 Tomas Sedlak HOME-PC PageOpen ProductSelectionDialog2 2011/11/5:14:58:36 Tomas Sedlak HOME-PC PageOpen FullProgressDialog 2011/11/5:14:58:36 Tomas Sedlak HOME-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1029.exe /q 2011/11/5:14:59:14 Tomas Sedlak HOME-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded 2011/11/5:14:59:14 Tomas Sedlak HOME-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent 2011/11/5:14:59:37 Tomas Sedlak HOME-PC Install DirectX Runtime Succeeded 2011/11/5:14:59:37 Tomas Sedlak HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/5:14:59:50 Tomas Sedlak HOME-PC Install FaroSDK Succeeded 2011/11/5:14:59:50 Tomas Sedlak HOME-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/5:15:00:07 Tomas Sedlak HOME-PC Install Autodesk Material Library 2012 Succeeded 2011/11/5:15:00:07 Tomas Sedlak HOME-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/11/5:15:00:27 Tomas Sedlak HOME-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded 2011/11/5:15:00:27 Tomas Sedlak HOME-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_ERZPH_Win_32bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TOMASS~1\AppData\Local\Temp\vcredist_x86_2005.log"" " 2011/11/5:15:00:42 Tomas Sedlak HOME-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2011/11/5:15:00:54 Tomas Sedlak HOME-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2011/11/5:15:01:15 Tomas Sedlak HOME-PC Rollback Autodesk Material Library 2012 Succeeded 2011/11/5:15:01:15 Tomas Sedlak HOME-PC Rollback FaroSDK Succeeded 2011/11/5:15:01:15 Tomas Sedlak HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2011/11/5:15:01:16 Tomas Sedlak HOME-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619 |
Zasláno: 07.lis.2011 v 09:29 |
Neměl na tom počítači instalovanou nějakou beta verzi AutoCADu? Ať zkusí onen .Net Framework (vč. Language packu) nainstalovat ručně předem. Instalační program už by se pak neměl pokoušet je instalovat znovu.
pavelstyl
Zasláno: 07.lis.2011 v 09:57 |
Děkuji za tip, předám ho dále.
Pavel Štyl
Stránka byla vygenerována za 0,645 sekund.
