statecny
Přihlášen: 01.říj.2004 Lokalita: ČR (JČ) Používám: Revit, Plant 3D, Navisworks, Advance Steel,BIM 360 Stav: Offline Bodů: 516 |
Téma: Katalog ocelových konstrukcí pro AutoCAD Plant 3DZasláno: 25.čer.2013 v 09:19 |
Na stránkách Autodesk Exchange je k dispozici ruský katalog ocelových konstrukcí. Katalog je určen pro AutoCAD Plant 3D 2013 a 2014.
Obsahuje 4150 konstrukčních prvků: 1 GOST 5267.1-90 Channels. Dimensions.
Assortment 2 GOST 8240-97 Hot-rolled steel
channels. Assortment 3 GOST 19772-93 Roll-formed steel
unequal les angles. Dimensions. Assortment 4 GOST 8509-93 Hot-rolled steel
equal-leg angles. Dimensions. Assortment 5 GOST 8510-86 Hot-rolled steel
unequal-leg angles. Dimensions. Assortment 6 GOST 19425-74 Special-purpose steel
I-beams and channels. Assortment 7 GOST 26020-83 Hot-rolled steel steel
I-beam with parallel flange edges. Assortment 8 GOST 8239-89 Hot-rolled steel flange
beams. Rolling products. Assortment 9 TU 14-2-685-86. Special-purpose
steel T-beams KT and T-beams SHT 10 GOST 8732-78 Seamless hot-deformed
steel pipes. Range of sizes. Assortment 11 GOST 10704-91 Electrically welded
steel line-weld lubes. Range. Assortment 12 GOST 8278-83 Roll-formed steel
channels. Dimensions. Assortment 13 GOST 8639-82 Square steel tubes.
Range. Assortment 14 GOST 8645-68 Rectangular steel tubes.
Range. Assortment 15 GOST 25577-83 Steel bent closed welded
square and rectangular sections. Specifications 16 GOST 30245-2003 Steel bent closed
welded square and rectangular section for building. Specifications 17 GOST 7417-75 Calibrated round steel.
Dimensions. Assortment 18 GOST 2590-88 Round steel bars.
Dimensions. Assortment 19 GOST 2591-88 Square Hot-rolled Steel
Bars Dimensions. Assortment 20 TU 36-2287-80 Square pipes 21 TU 67-2287-80 Rectangular pipes 22 GOST 4121-96 Crane rails.
Specifications |
Václav Statečný
Arkance Systems CZ s.r.o. |
Stránka byla vygenerována za 0,299 sekund.
