Téma uzavřenoService pack 2 pro AutoCAD Plant 3D/PID 2015
statecny Zobrazit panel
Přihlášen: 01.říj.2004
Bodů: 516
Přímý odkaz na tuto zprávu Téma: Service pack 2 pro AutoCAD Plant 3D/PID 2015
    Zasláno: 18.lis.2014 v 13:14
Byl uveden Service Pack 2 pro AutoCAD Plant 3D 2015 a AutoCAD P&ID 2015.
Service pack je určen pro 32bit i pro 64bit verzi.
V případě, že se chytáte instalovat také Extension 1 pro AutoCAD Plant 3D 2015, musíte ho nainstalovat ještě před Service Pack 2.
Service pack 2 můžete stáhnout na stránce Download
Seznam oprav a vylepšení:
P&ID
  • The pipe line group did not acquire the drawing area property.
  • Nozzles would always be removed from equipment if a connected line was erased. If SLINENOZZLEERASE is set to false, nozzles do not erase.
  • General instruments could not be rotated. If GENERALINSTRUMENTROTATE is set to true, inline components can now be rotated.
  • Zooming to the other page of an off-page-connector did not work.
  • After unlinking an sline, it could not be linked together again.
Plant Vault Projects
  • Project description changes would not update in the vault.
  • The plant project workspace was not correct if variables (for example: %username%) were used.
  • The Document Editor (Level 2) role did not allow you to check in drawings.
Fixes that apply to AutoCAD Plant 3D only:
3D Model
  • Olets would not always orient correctly after being copied.
Isometric Drawings
  • Socket weld symbols did not always display correctly for a nipple connected to a socket weld fitting.
  • Olets connected to piping on opposite sides did not always display correctly.
  • Isometric BOM did not recognize Unicode property names.
  • Insulation annotation with pipe tracing did not always display correctly.
  • Title block attributes with center justification did not always display correctly.
  • Multiple pipe supports would sometimes display with no space between them.
  • Text height of line number annotations did not always display correctly.
  • Bolt set weights were not included in the bill of material.
Orthographic Drawings
  • Annotation in a mixed-metric project initially displays metric units.
  • If two ortho drawings had the same name (in different folders), ortho views could not be created.
  • Existing piping did not display on the EXIST_CENTER layer.
  • Dynamic block symbols did not display the expected visibility state.
Piping Specs
  • Actuators could not be created in a metric catalog.
  • Bolt length size descriptions were incorrect after a spec update in mixed metric projects.
  • When adding a new part to a spec the part list priority for existing parts was not preserved.
Václav Statečný
Arkance Systems CZ s.r.o.
Tip 9929:Problém s připojením na WMS služby z AutoCADu Map 3D 2015.
Tip 10120:Nefungující připojení na WMS zdroj dat v Civil3D 2015.
Tip 10009:Nefunguje mi kopie rozvržení pomocí Ctrl+přetažení v AutoCADu 2015.
Tip 10034:Po přepnutí do prostředí jednoho dokumentu nezná AutoCAD Electrical některé příkazy.
Tip 10640:V jakém pořadí instalovat service packy CAD produktů?
Tip 10179:VIPMapování symbolu ventilu PID na uživatelský prvek Plant 3D.
Stránka byla vygenerována za 0,203 sekund.
