Téma uzavřenoInventor HSM 2015 SP6
Bodů: 22267
Přímý odkaz na tuto zprávu Téma: Inventor HSM 2015 SP6
    Zasláno: 20.led.2015 v 12:26
Byl uveden "Update 6" pro CAM aplikaci Autodesk Inventor HSM 2015 a HSM Pro 2015. Viz Application Manager a sekce Download. Přehled novinek:
1. Added new stay-down feature for Adaptive Clearing available on the linking tab called Stay-down level. Use this setting to control when to stay down rather than doing retracts. If your CNC machine does slow retracts compared to high feed moves you will generally want Adaptive Clearing to stay-down more in which case you need to increase the new level setting. Note that the calculation time can increase significantly as you increase the stay-down level. The feature is turned off by default for now. The stay-down will not engage stock and hence use the no-engagement feed as the normal stay-down moves.
2. Added support for minimum axial engagement for Adaptive Clearing. Use this setting to ensure that at least one flute is always engaged during the intermediate steps to avoid chatter and reduce tool wear.
3. Added support for ramp with taper for both 2D and 3D Adaptive Clearing for improved chip escape.
4. Added support for chip thinning for the Face strategy.
5. Added generic Othermill/Otherplan post.
6. Updated generic post processor configurations with fixes and improvements.
7. Added a warning dialog to better handle Drill height plane definition.
8. Capacity improvement when selecting geometry contours.
9. Fixed the issue that helix Ramp doesn’t work for 2D Pocket and Pocket operations.
10. Bunch of enhancements for Swarf contour selection.
11. Added two new context menus (Go to Previous Event and Go to Next Event) to Simulation. These allow jumping to the previous or next collision event on the position bar.
Tip 12502:VIPJak přidat nový postprocesor do Inventor CAM (HSM)
Tip 11383:VIPJak získat souřadnice obráběcí cesty z CAM aplikace Inventor HSM v CSV nebo DXF?
Tip 10132:Distribuovaný výpočet CAM úlohy v Inventor HSM.
Tip 12578:VIPInventor CAM funguje po instalaci jen v režimu Express
Tip 10861:VIPInventor HSM - další klávesové zkratky (se Shift)
Tip 10867:VIPInventor HSM - nastavení cesty pro ukládání NC kódu.
Stránka byla vygenerována za 4,434 sekund.
