Téma uzavřenoRevit 2015 R2 UR6
Bodů: 22234
Přímý odkaz na tuto zprávu Téma: Revit 2015 R2 UR6
    Zasláno: 02.úno.2015 v 09:13
Byla uvedena "Update Release 6" (UR6, SP6) pro Revit 2015 R2. Ke stažení viz Download (zatím jen pro all-in-one Revit). Přehled oprav:
Improvements made in Update Release 6 build (20140127_0715):
Revit® Architecture 2015 Updates
Corrects the behavior that caused view templates to apply incorrectly for some views, if a temporary view template was also applied to the view.*
 Improves stability when editing a families.*
 Improves loading and editing families which contain extensible storage.*
 Allows type parameters in upgraded families to swap from one type to another.*
 Improves stability when upgrading a project which contains corrupt families.*
 Improves notification reliability when closing a workset in which a rvt file link has been placed.*
 Improves stability while opening the Material Dialog.
Revit® MEP 2015 Updates
Improves highlighting of circuits in the plan view from a panel schedule or System Browser.*
Revit® API 2015 Updates
Improves querying of point cloud on RCS files using the Revit pointcloud API.*
Tip 9808:Je Revit Server kompatibilní s Windows Server 2012?
Tip 10134:Revit: Rodina je poškozena a nelze ji upravit.
Tip 6113:VIPMohu používat licenční server FlexLM na virtuálním serveru VMware?
Tip 10087:Snazší vložení nového řádku do výkazu v Revitu.
Tip 10049:Nastavení barvy pozadí v Revitu.
Stránka byla vygenerována za 0,207 sekund.
