Téma uzavřenoRevit 2015 R2 UR11 a Revit 2016 R2 Update 1
Bodů: 22240
Přímý odkaz na tuto zprávu Téma: Revit 2015 R2 UR11 a Revit 2016 R2 Update 1
    Zasláno: 18.pro.2015 v 23:04
Byly uvedeny dvě aktualizace pro Autodesk Revit - Revit 2015 R2 a Revit 2016 R2. Obě vám nabídne Application Manager.
Přehled oprav:
Autodesk® Revit® Platform 2015 Updates
- Improves stability after editing a dimension witness line and then moving the mouse outside of the Properties palette.
- Improves stability when creating dimensions.
- Improves stability when working within a worksharing model with central files on an unstable network environment.
- Improves stability when modifying a schedule’s appearance when the schedule does not contain table contents and headers.
Autodesk® Revit® API 2015 Updates
- Improves stability when encountering conflicting non-unique extensible storage schemas.
Revit 2016
 Improves stability when encountering conflicting non-unique extensible storage schemas.*
Update 1 for Release 2 Platform Annotation Improves stability when creating aligned dimensions.*
Improves stability after editing a dimension witness line and then moving the cursor outside of the Properties palette.*
Design Option Improves stability while making a design option primary.*
Family Improves stability when importing .adsk files.*
Export DWG/DXF/DWF Improves export reliability when there are invalid characters in properties.*
Improves export reliability when exporting the current view as a .DWF.*
Point Clouds Improves stability when switching visual styles from Ray Trace to Realistic, if a large point cloud file is in the model.*
Schedule Improves stability in schedules when modifying schedule appearance which does not contain table contents and headers.*
Startup/Close and Audit Improves stability when closing documents with color fills applied.*
Upgrade Improves stability when attempting to cancel a file open command.*
Other Improves stability when selecting potentially invalid or damaged elements.*
Improves stability by reducing the system resource usage Revit requires when multiple views are open.*
Corrects an issue in which keyboard shortcuts for copying and pasting from clipboard (Ctrl+C and CTRL+V) did not work as expected in a perspective view.*
Improves performance when moving a crop region for a view.*
Architecture Ceiling Improves stability when creating an automatic ceiling.*
Stair Improves stability when editing the minimum stair run width.*
MEP Mechanical Settings Corrects an issue with pressure drop calculation that occurred when searching ASHRAE tables for dampers.*
API Corrects an issue when copying Welded Wire Meshes from one host to another.*
Corrects an exception which occurred when invoking PickObject API via PostCommand.*
Corrects an issue which prohibited downcast from View to ViewSheet.*
marko10 Zobrazit panel
Přihlášen: 25.lis.2011
Lokalita: ČR (ÚL)
REVIT
Bodů: 76
Přímý odkaz na tuto zprávu Zasláno: 21.pro.2015 v 17:57
Dobrý den, v sekci ještě není update Revit 2016 R2 Update 1 ??? nebo se může nainstalovat update pro Revit 2016 Architecture. děkuji
Bodů: 22240
Přímý odkaz na tuto zprávu Zasláno: 21.pro.2015 v 18:18
Ne, to je jiný update. Máte pravdu, že odkaz chyběl - doplněno.
Lokalita: ČR (ÚL)
REVIT
Bodů: 76
Přímý odkaz na tuto zprávu Zasláno: 21.pro.2015 v 19:26
Děkuji Vám, a přeji hezké prožití Vánočních svátků a hodně obchodních úspěchů.
Tip 9808:Je Revit Server kompatibilní s Windows Server 2012?
Tip 10134:Revit: Rodina je poškozena a nelze ji upravit.
Tip 11616:Po instalaci Win10 Anniversary Update mi v Revitu 2016 zmizel panel rychlého spuštení (QAT)
Tip 6113:VIPMohu používat licenční server FlexLM na virtuálním serveru VMware?
Tip 10545:Jaké verze databáze Oracle jsou podporovány v AutoCAD Map 3D 2016?
Tip 10087:Snazší vložení nového řádku do výkazu v Revitu.
Stránka byla vygenerována za 0,313 sekund.
