Používám: Implementujeme řešení Autodesk Stav: Offline
Bodů: 22208
Téma: Uveden SP1 pro Revit 2017 Zasláno: 10.čer.2016 v 07:43
Byl uveden Service Pack 1 pro Revit 2017 a pro Revit LT 2017. Aktualizuje všechny verze Revitu 2017, včetně Revitu v sadách Autodesk Building Design Suite 2017, Autodesk Infrastructure Design Suite 2017, Autodesk Plant Design Suite 2017, Autodesk Structural Fabrication Suite 2017, Autodesk MEP Fabrication Suite 2017 a Autodesk Revit Collaboration Suite 2017.
SP1 je ke stažení na stránce Download nebo přes Desktop App.
Přehled oprav v SP1:
Service Pack 1
Platform
Family
Corrects the positioning of shared nested family instances in a host family.*
Graphics
Improves performance when the "Allow Navigation During Redraw" option is enabled.*
Improves stability when an .rvt file is drag/dropped onto Revit.exe which launches in WARP (software) mode.
Keyboard Shortcuts
Corrects an issue with truncated keyboard shortcut names in the status bar.
Linked RVT Files
Improves stability when reloading linked projects.
Mass
Improves stability while placing masses in a model.
Material
Corrects an issue in which the preview image within the Initial Color dialog for lighting fixtures is missing when Revit is installed on Window 8.1 and Windows 10 systems.
Open/Save
Corrects an issue which prevents saving of projects when a product crash occurred.
Parameters
Corrects visibility of the Associate Family Parameter tooltip.*
Corrects an issue which allows the association of global parameters to built-in family type parameters before a value has been entered into the family type parameter.
Point Clouds
Enables snapping to point clouds.*
Print
Corrects an issue where hatch patterns from linked underlay elements were printing but not displayed.*
Corrects an issue causing some wall tags and duct tags to not print during batch plot.*
Corrects an issue where printing the visible portion of window while a non-rectangular crop region is defined causes model geometry to disappear.*
Schedule
Renames "Standard" from the schedules formatting tab to "No calculation".
Corrects an issue in which Revit hangs when editing a text parameter in the schedule if the drop-down list contains an empty line.*
Improves stability when sync with central while editing text in a schedule.
Improves stability when editing text in schedule.
User Interface
Allows the column width of the type properties dialog to continue to be adjustable.
Corrects an issue that could cause Revit to hang when the focus is switched to a dialog.
Corrects an issue when using properties dialog in group edit mode.
Improves stability when launching tools from the Quick Access Toolbar while working in Family Editor.
Improves stability when exiting Revit during startup.
Architecture
Energy
Corrects an issue where override settings for Analytic Constructions were lost in Heating and Cooling Load Calculations.
Improves stability when running an energy simulation that uses overrides for Schematic Types.
Stair
Improves stability when placing stairs in floor plan views.*
Wall
Improves stability when editing a wall assembly.
Improves stability when using automatic wall joins.*
MEP
Fabrication
Improves the alignment accuracy of straight runs when using the Optimize Straights feature.
Improves the edge line display on rising/falling insulated pipe tees.
Corrects an issue that could cause fittings to be deleted when reloading a Fabrication configuration.
Improves placement of Combo fittings in sloped pipe systems.*
Enables services to be swapped on fabrication parts if valid.
Enables quick connection tool within section and elevation views.
Improves stability when using the Quick Connect tool on transition fittings that are connected as taps.
System Browser
Improves stability when deleting items through the System Browser.
Improves stability when closing a view while the System Browser is open.
Upgrade
Improves stability when upgrading a project that contains a family with a nested pipe or duct fitting or accessory.
Structure
Annotation
Corrects an issue with rebar numbering when the rebar is contained within a group.*
Reinforcement - Couplers
Corrects an issue with rebar couplers when modifying bar parameters using the Properties palette.
Corrects an issue with rebar couplers when using the space bar to rotate a rebar element.
Reinforcement - Rebar
Improves stability when changing views during rebar sketch.
API
Corrects an issue which caused the API sample BRepBuilderExample from compiling.*
Improves stability when importing geometry with many faces using the API.*
Adds a SDK sample for BrepBuilder usage.
Improves performance when creating thousands of pipes through API.*
Vladimír Michl (moderátor) ARKANCE CZ - arkance.world (podpora viz emea.support.arkance.world)
Nemůžete vytvářet nová témata v tomto fóru Nemůžete odpovídat na témata v tomto fóru Nemůžete vymazávat vaše příspěvky v tomto fóru Nemůžete upravovat vaše příspěvky v tomto fóru Nemůžete vytvářet ankety v tomto fóru Nemůžete hlasovat v anketách v tomto fóru
