Přes 122.000 registrovaných u nás, celkem 1.119.000 registrovaných (CZ+EN).
alebaci
Přihlášen: 17.kvě.2011 Lokalita: ČR (PL) Používám: autocad architecture Stav: Offline Bodů: 11 |
Téma: instalace Autocadu ArchitectureZasláno: 30.zář.2016 v 08:02 |
Zdravím!
Nejde mi instalovat Autocad Architecture a hlásí mi soubor s instalačním protokolem: 2016/9/29:21:05:02 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:21:05:02 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:05:02 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIA9F1.tmp 2016/9/29:21:05:02 Alenka ALENKOMP Launch 2016/9/29:21:05:39 Alenka ALENKOMP === Setup ended === 2016/9/29:21:04:54 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:21:04:54 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:04:54 Alenka ALENKOMP Current Directory C:\Autodesk\AutoCAD_Architecture_2014_Czech_Win_32_64bit_wi_cs-CZ 2016/9/29:21:04:54 Alenka ALENKOMP Launch 2016/9/29:21:04:54 Alenka ALENKOMP CommandLine 2016/9/29:21:04:54 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:04:54 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIA9F1.tmp 2016/9/29:21:05:39 Alenka ALENKOMP === Setup ended === 2016/9/29:21:09:26 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:21:09:26 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:09:26 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIBFC7.tmp 2016/9/29:21:09:26 Alenka ALENKOMP Launch 2016/9/29:21:09:45 Alenka ALENKOMP === Setup ended === 2016/9/29:21:09:21 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:21:09:21 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:09:21 Alenka ALENKOMP Current Directory C:\Autodesk\AutoCAD_Architecture_2014_Czech_Win_32_64bit_wi_cs-CZ 2016/9/29:21:09:21 Alenka ALENKOMP Launch 2016/9/29:21:09:21 Alenka ALENKOMP CommandLine 2016/9/29:21:09:21 Alenka ALENKOMP Path_Length: 155 2016/9/29:21:09:21 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIBFC7.tmp 2016/9/29:21:09:47 Alenka ALENKOMP === Setup ended === 2016/9/29:22:34:36 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:22:34:36 Alenka ALENKOMP Path_Length: 155 2016/9/29:22:34:36 Alenka ALENKOMP Current Directory C:\Autodesk\AutoCAD_Architecture_2014_Czech_Win_64bit_dlm 2016/9/29:22:34:36 Alenka ALENKOMP Launch 2016/9/29:22:34:36 Alenka ALENKOMP CommandLine 2016/9/29:22:34:36 Alenka ALENKOMP Path_Length: 155 2016/9/29:22:34:36 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AICAC8.tmp 2016/9/29:22:35:12 Alenka ALENKOMP === Setup ended === 2016/9/29:22:34:45 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/29:22:34:45 Alenka ALENKOMP Path_Length: 155 2016/9/29:22:34:45 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AICAC8.tmp 2016/9/29:22:34:45 Alenka ALENKOMP Launch 2016/9/29:22:34:46 Alenka ALENKOMP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alenka\AppData\Local\Temp\_AICAC8.tmp\Setup\AcSetup.dll 2016/9/29:22:34:46 Alenka ALENKOMP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2016/9/29:22:34:57 Alenka ALENKOMP PageOpen LaunchDialog 2016/9/29:22:35:20 Alenka ALENKOMP PageOpen LicenseDialog 2016/9/29:22:35:25 Alenka ALENKOMP PageOpen ProductInfoDialog 2016/9/29:22:36:30 Alenka ALENKOMP PageOpen ProductSelectionDialog2 2016/9/29:22:36:40 Alenka ALENKOMP PageOpen FullProgressDialog 2016/9/29:22:36:40 Alenka ALENKOMP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_Architecture_2014_Czech_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Alenka\AppData\Local\Temp\vcredist_x86_2010.log 2016/9/29:22:36:49 Alenka ALENKOMP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603 Nevíte někdo prosím co s tím? Už jsem bezradná |
splonk
Přihlášen: 25.lis.2006 Lokalita: ČR (Pha) Používám: Implementujeme řešení Autodesk Stav: Offline Bodů: 1279 |
Řešení Zasláno: 30.zář.2016 v 09:00 |
Dobry den,
pan Michl ma pravdu, z prilozeneho obrazku to vypada na win10. Mne se ale instalace ACA 2014 (eng) na win 10 x64 podarila v pohode... a to na vice ruznich strojich...?! A zatim (vicemene) funguji v poradku... Parvda ale je, ze kdyz narazim(e) na neco co se chova nestandardtne tak clovek nevi, zda chybu hledat v samotne aplikaci, nebo ve vyse zminene nekompatibilite... Ale i to ma sva reseni... :) Alence bych doporucil totez co pan Michl... instalovat aktualni verzi ACA... A pokud z nejakych duvodu lpi na verzi 2014 (nap jako ja, kvuli kompatibilite nekterych utilit a addinu) tak bych mozna doporucil onen error z logu zadat do Googlu a dostanete se treba na stranku: kde se o tomuto neco pise... Pak je tam stranka dalsi a dalsi... proste je to cena za to, ze my, obycejni smrtelnici chceme byt chitrejsi ne Microsoft (Autodesk!?)...:-) Ale jeste nez zacnete bych doporucil par "zakladnich pravidel" ktere je dobre pouzivat pri instalaci jakehokoliv produktu.... Cituji ze vyse vlozeneho odkazu:
Tak hodne stesti a dejte vedet, jak jste dopadla JASponza
JASponza
ARKANCE Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: Implementujeme řešení Autodesk Stav: Offline Bodů: 22152 |
Zasláno: 30.zář.2016 v 08:24 |
Není to náhodou ve Windows 10? Staré verze 2014 s ním nejsou kompatibilní.
alebaci
Zasláno: 30.zář.2016 v 08:49 |
Bohužel ne, to vygenerovalo toto:
2016/9/30:08:43:55 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/30:08:43:55 Alenka ALENKOMP Path_Length: 154 2016/9/30:08:43:55 Alenka ALENKOMP Current Directory C:\Autodesk\AutoCAD_Architecture_2016_Czech_Win_64bit_dlm 2016/9/30:08:43:55 Alenka ALENKOMP Launch 2016/9/30:08:43:55 Alenka ALENKOMP CommandLine 2016/9/30:08:43:55 Alenka ALENKOMP Path_Length: 154 2016/9/30:08:43:55 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIA3DD.tmp 2016/9/30:08:44:44 Alenka ALENKOMP === Setup ended === 2016/9/30:08:44:03 Alenka ALENKOMP === Setup started on ALENKOMP by Alenka === 2016/9/30:08:44:03 Alenka ALENKOMP Path_Length: 154 2016/9/30:08:44:03 Alenka ALENKOMP Current Directory C:\Users\Alenka\AppData\Local\Temp\_AIA3DD.tmp 2016/9/30:08:44:03 Alenka ALENKOMP Launch 2016/9/30:08:44:08 Alenka ALENKOMP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alenka\AppData\Local\Temp\_AIA3DD.tmp\Setup\AcSetup.dll 2016/9/30:08:44:08 Alenka ALENKOMP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2016/9/30:08:44:28 Alenka ALENKOMP PageOpen LaunchDialog 2016/9/30:08:47:56 Alenka ALENKOMP PageOpen LicenseDialog 2016/9/30:08:48:07 Alenka ALENKOMP PageOpen ProductInfoDialog 2016/9/30:08:48:32 Alenka ALENKOMP PageOpen ProductSelectionDialog2 2016/9/30:08:48:38 Alenka ALENKOMP PageOpen FullProgressDialog 2016/9/30:08:48:38 Alenka ALENKOMP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_Architecture_2016_Czech_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Alenka\AppData\Local\Temp\vcredist_x86_2010.log 2016/9/30:08:48:47 Alenka ALENKOMP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603 |
splonk
Přihlášen: 25.lis.2006 Lokalita: ČR (Pha) Používám: AutoCAD/ACA'21, '24, RVT'21, '24 Stav: Offline Bodů: 1279 |
Dobry den,
JASponza
Zasláno: 30.zář.2016 v 09:16 |
Pro Win10 je nejjistější použít aktuální verzi - tedy 2017 SP1, ale problém může být způsoben i nedostatečnými právy, antivirem, plnou složkou TEMP a dalšími vlivy.
Stránka byla vygenerována za 0,547 sekund.
