IFC Export pro Revit 2018 |
Odpovědět | archiv |
Autor | |
Moderátor Arkance Systems Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: Dodáváme produkty Autodesk Stav: Offline Bodů: 21470 |
Téma: IFC Export pro Revit 2018 Zasláno: 26.úno.2018 v 18:27 |
Byla uvedena nová verze aplikace pro rozšířený export IFC z Revitu 2018 - V2.3.1 (viz Download a Apps). Přehled nejdůležitějších novinek (zejména viz volba počátku):
New Export Functionality: - Add the ability to import and export custom configuration setups. - Add the ability to choose the origin of the exported file. There are 4 options: - Current shared coordinates origin - Internal Revit coordinates - Project Base Point - Site Surve Point - A number of COBie improvements, including: - Including the exchange requirement information in the File Header - A number of IFC4 Reference View improvements, including: - Export some profile names with geometry when appropriate - Fix scaling of triangulation coordinates - Improve export of beam axis - Restrict use of many disallowed IFC entities and geometries - Allow remapping of IFC entity attributes in addition to properties. - Create more associated type entities for IFC objects. - Consistent ability to override name, object type and description for all entities - Export connectors even if they aren't connected to other elements. - Export parts whose host elements are in linked files, whether "Export Parts as Building Elements" is checked or not. - Improved creation of IFCBUILDING and IFCSITE entities Export Bug Fixes: - Fix export of some space with empty Occupant fields. - Fix relative placement of exported IFC links to the host IFC file. - Fix unexpected error when exporting a floor as an IfcRamp (for IFC2x3 only). - Fix unexpected error when exporting a site from a 3D view when exporting the active view geometry (for IFC4 RV only). - Full French localization for a number of previously hard-coded strings - Improved calculation of some property set parameters. |
Odpovědět | |
Stránka byla vygenerována za 0,686 sekund.
