Přes 123.000 registrovaných u nás, celkem 1.132.000 registrovaných (CZ+EN).
ARKANCE Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: Implementujeme řešení Autodesk Stav: Offline Bodů: 22228 |
Téma: Aktualizace AutoCAD 2018.1.2Zasláno: 19.bře.2018 v 18:13 |
Byla uvedena aktualizace 2018.1.2 pro AutoCAD (včetně profesních verzí) a AutoCAD LT. Ke stažení je v Autodesk Account nebo pomocí Desktop App.
Přehled oprav: * Point Cloud - Occasional crashes when adding color schemes to point clouds no longer occur. * General - Occasional crashes when detaching external references in some visual styles no longer occur. - Occasional crashes when importing or attaching DGN drawings with some spline types no longer occur. - Occasional crashes when getting the UCS coordinate values from a dimension no longer occur. * Display - The image of a Web URL in the drawing displays correctly. * Model Documentation - No error dialog box displays after completing certain Model Documentation commands. * MText - The characters show correctly when using double-byte characters with certain settings. * PDF / Plot - PDF files plotted using certain visual styles display correctly. - The plot result remains correct after changing the visual style in model space. * General - Object snap settings remain turned on during view editing commands. - AutoCAD startup time and network drive scanning speed are improved. - The dynamic input tooltips for dimensions display correctly on all supported operating systems. |
Stránka byla vygenerována za 0,303 sekund.
