Téma uzavřenoAktualizace Vault 2019.1.1
ARKANCE
Bodů: 22215
Přímý odkaz na tuto zprávu Téma: Aktualizace Vault 2019.1.1
    Zasláno: 20.lis.2018 v 08:26
Byl vydán hotfix 2019.1.1 pro Vault Server a Client. Opravuje několik nalezených chyb. Instalaci je potřeba synchronizovat na serveru a všech klientech a jako obvykle ověřit kompatibilitu s případnými enterprise nadstavbami.
Přehled oprav verze 2019.1.1:
Known Issues
Add-ins: Revit
Unexpected error dialog pops up when a file is clicked using Revit load family, if Revit indexing is disabled or indexing in progress PDM-22094
Fixed Issues
Add-ins: ACAD
Resolved issue of Assertion Failed when executing Update Properties in Vault ribbon in AutoCAD Mechanical PDM-21233
Add-ins: Inventor
Improved stability when using the Inventor Save and Save As commands with Vault Inventor-Addin. PDM-21582
Prevent Inventor files relationship being lost in Vault when checking in iNest files. PDM-21687
Add-ins: Third Party
Corrected incorrect status icon if file checked in during closing of the Office applications PDM-21401
Behaviors
Resolved issue where a file could be changed to a denied lifecycle state by changing the lifecycle definition. PDM-21511
Client
Resolved the issue with Send link command is showing broken link for Thin Client if the Vault name has space PDM-21287
Provided Vault side support for Civil 3D Sample Line Groups and sample line object, feature available together with Civil 3D 2019.2 onwards. PDM-21333
Resolved the issue with change in the color of small icons in Vault client, for locked file and when the local copy is not up-to-date to better differentiate the files. PDM-21271
Resolved an issue where an Office file custom property name text is garbled when modifying the property's value within Vault Explorer. PDM-21107
Resolved an issue where Batch Plot was not sending the proper number of copies to the printer when printing with a visualization file. PDM-21565
Resolved the issue with sorting the list of files selected for bulk update of metadata or user defined properties. PDM-21842
Data Standards
Resolved the issue with Save Copy As command in Vault data standard for Inventor, in which Inventor lead to an unintended exit. PDM-21521
Resolved the issue with the truncation $Prop["_FolderName"] property value for Folder name with Vault Data Standard for Client. PDM-21775
Resolved the issue with 'Copy' command with Vault Data Standard in AutoCAD. PDM-21757
Resolved an issue for using 'Update Property Using Date Only' option with Data Standard for AutoCAD. PDM-21758
Resolved the issue with Data Standard Save command leading to unintended exit of the Data Standard, when a template including iPropery with Fx function is used. PDM-21547
Resolved an issue with Data Standard for AutoCAD, where Data standard now allows for empty fields. PDM-21961
Resolved issue with Vault Numbering Scheme not working properly when the Frame Generator command is suppressed for Data Standard for Inventor. PDM-22140
Resolved an with issue Data Standard resulting in unintended exit of Inventor, when used with Factory Design Utility 2019.1 update Sync to ACAD capability. PDM-22148
Items
Resolved the issue that UDP's on Items are not populated if file is not checked out/checkin PDM-21456
Server
Resolved an issue with a property display name being incorrectly truncated after 60 characters, it now supports up to 100 characters. PDM-21890
Resolved an issue with the ADMS Console in which an AVFS fails to replicate after upgrading to 2019. PDM-21171
Improved the performance of Revit load family PDM-20864
Thin Client
Corrected the visualization file version been downloaded at thin client File Details panel and History tab PDM-21227
ARKANCE CZ - arkance.world
Tip 11922:VIPChyba "Vault AddIn nemůže najít služby správy dat" po Windows update.
Tip 12099:Číslování součástí rámu pomocí Vaultu.
Tip 13545:VIPInstalace Revit Update (nebo jiné aktualizace) končí chybou 101 (nebo jiným selháním)
Tip 12055:Inventor 2019 zobrazuje vazby "Proti sobě" jako "Tečnost".
Tip 11971:Cloudový Autodesk Viewer nezobrazí některé strojařské značky v DWG.
Tip 12363:VIPChyba ve Vault Job Processor protokolu logger.log po aktualizaci na verzi 2020.1
Stránka byla vygenerována za 0,254 sekund.
