Téma uzavřenoAktualizace Inventor 2019.3 a 2019.0.2
Bodů: 22234
Přímý odkaz na tuto zprávu Téma: Aktualizace Inventor 2019.3 a 2019.0.2
    Zasláno: 17.pro.2018 v 20:16
Byly vydány aktualizace pro Inventor 2019 - 2019.0.2 a subscription release Inventor 2019.3. Ke stažení jsou na Autodesk Account nebo přes Desktop App.
Přehled oprav 2019.0.2
Assemblies - Constraints-Joint-Assemble
Improved performance when using Rebuild All on migrated data. INVGEN-22153
Security
Improved security by removing FBX dependency. INVGEN-22601
Platform
Improvements made to the Customer Error Reporting program. INVGEN-22727
Platform - Framework
Resolved issue where auto-centering was not functioning correctly when performing an orbit operation with a 3Dconnexion Space Mouse. INVGEN-23174
Přehled oprav 2019.3
Add-Ins - Frame Generator
Improved stability when using Frame Generator with the Vault Add-In. INVGEN-22733
Improved stability when using Frame Generator. INVGEN-22967
Improved stability when using Frame Generator. INVGEN-22968
Add-Ins - Tube and Pipe
The holes in the tube created with Tube & Pipe are now computed in correct order. INVGEN-20422
Improved performance when using Rebuild All on migrated data. INVGEN-22035
Assemblies - Derived-Shrinkwrap
Improved stability when moving End Of Part marker. INVGEN-21304
Security
Parts - Hole-Threads
There are no longer differences between the Tolerance values displayed in the Hole dialog box and the graphics window when retrieving dimensions in Inventor drawings. INVGEN-21521
Parts - Properties
The iProperty date value now shows the correct date. INVGEN-22400
Platform
File name is no longer cut off after the last delimiter when exporting to a different CAD format. INVGEN-19569
Resolved issue where auto-centering was not functioning correctly when performing an orbit operation with a 3Dconnexion Space Mouse. INVGEN-22656
Translators - DWG
Resolved issues with dual dimensions in a .dwg file being exported incorrectly to a .idw file. INVGEN-22344
Improved stability when editing an AutoCAD block. INVGEN-22896
UI
Improved stability for font settings. INVGEN-22817
Tip 12219:Po instalaci aktualizace Inventor 2019.4 se mi nenačítá Nesting Utility.
Tip 12099:Číslování součástí rámu pomocí Vaultu.
Tip 12055:Inventor 2019 zobrazuje vazby "Proti sobě" jako "Tečnost".
Tip 11922:VIPChyba "Vault AddIn nemůže najít služby správy dat" po Windows update.
Tip 11971:Cloudový Autodesk Viewer nezobrazí některé strojařské značky v DWG.
Tip 9940:Jde do Revitu načíst SKP soubory ze SketchUp 2013, 2018, 2019 či 2020?
Stránka byla vygenerována za 0,352 sekund.
