Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: řešení Autodesk Stav: Offline Bodů: 22240 |
Téma: Vydán hotfix Revit 2019.2.1Zasláno: 07.bře.2019 v 16:29 |
Byl vydán hotfix pro Revit 2019.2 a pro Revit LT 2019.2. Ke stažení je na Autodesk Accounts nebo pomocí Desktop App.
Přehled oprav (navíc aktualizuje komponenty Collaboration for Revit 2019, Dynamo Core a Dynamo Revit): 2019.2.1 Hotfix Resolved Issues * Resolved an issue that prevented export to dwg of multiple views/sheets. * Resolved an issue where monitored openings did not update when changes are made to the original object. * Resolved an issue that could cause MEP Fabrication elements to disconnect when reloading a Fabrication configuration. * Improved stability when opening a corrupt cloud model from Revit Home. * Resolved an issue where Revit Home could not show all cloud models when there were more than 200 files in a BIM 360 Document folder. * Resolved an issue that prevented steel fabrication elements from being visible after adding it in a cloud model in BIM 360. * Resolved an issue when using the rollback workflow in a workshared model and the central model contained steel fabrication. * Resolved an issue where Non-workshared models stored in BIM 360 could not be exported to IFC. * Saving a model as a cloud model is now blocked if there are any background tasks in progress at that time. |
Stránka byla vygenerována za 0,359 sekund.
