Téma uzavřenoNový Plant 3D 2020.1 a Plant 3D 2019.2
ARKANCE
Bodů: 22215
Přímý odkaz na tuto zprávu Téma: Nový Plant 3D 2020.1 a Plant 3D 2019.2
    Zasláno: 15.srp.2019 v 06:48
Byly uvedeny dvě aktualizované verze AutoCADu Plant 3D verzí 2020 (2020.1) a 2019 (2019.2) pro předplatitele. Ke stažení jsou na Autodesk Account a přes Desktop App.
Přehled změn a oprav je u obou prakticky stejný:
Collaboration Workflow
Fixed an issue where opening collaboration projects failed in some special network settings.
Collaboration workflow now detects system proxy settings correctly.
New projects are now created correctly from a collaboration project template.
Performance improvements for opening collaboration projects and drawings.
Cross-drawing connection information can now be restored correctly after removing and copying back the drawings to a collaboration project.
A new command "PLANTAUDITDATABASE" is available to project administrators for auditing a project database in the Cloud.
Vault Workflow
Fixed an issue where migrating vault projects from a 2016 version failed in certain cases.
Duplicate vault projects were shown in the open dialog in some cases.
Performance improvements for opening vault projects and drawings.
P&ID
P&ID Symbol blocks can now be edited via project setup for non-English versions.
The application hangs in some P&ID painter setting special cases.
Inline assets can now rotate correctly when moving a line.
From/to properties now show correct values in the properties palette when connecting a line with a reducer.
Piping
Fixed an issue where the piping spec can't be changed in the properties palette with certain tag format settings.
Status property is now updated correctly in the properties palette after changing the piping spec.
The "PLANTAUDIT" command can now correct corrupted piping geometries.
Cut length is now calculated correctly for pipe bends.
Bolt length is now calculated correctly for wafer components.
Piping fittings can now be connected to lap end flanges correctly.
Elbows can now rotate correctly with slope.
Isometrics
Annotation for insulation break now points to correct location.
Makeup length can now be added to bill of materials and cut piece list correctly for spool drawings.
Makeup length is now added to pipe dimension for spool drawings. To turn this off, set "AddMakeupLengthForSpool=false" in Dimensions settings of Isoconfig.xml.
Fixed an issue where the PCF export failed in certain conditions.
Orthographics
Fixed an issue that may cause the application to crash when updating orthographic views.
Spec Editor
The removed part can now be restored in spec.
Bolt length is now updated in the catalog.
Spec export now generates common properties in Spec Data sheet.
ARKANCE CZ - arkance.world
Tip 12249:VIPJak exportovat FBX z AutoCADu 2019, 2020?
Tip 12067:Po instalaci AutoCAD Plant 3D 2019 zmizí některé parametry v paletě vlastností.
Tip 12130:Při zarovnání textu v buňce reportu dojde k zamrznutí Report Creatoru.
Tip 12733:Některé komponenty se v modelu Plant 3D přestaly zobrazovat.
Tip 12666:Použití izolace v Plant 3D pro kontrolu kolizí.
Tip 10335:VIPJak přidat nový rozměr prvků při vytváření uživatelských prvků v Plant 3D.
Stránka byla vygenerována za 0,188 sekund.
