Používám: řešení Autodesk Stav: Offline
Bodů: 22272
Téma: Aktualizace Inventor 2020.1.1 a 2019.4.2 Zasláno: 25.zář.2019 v 05:37
Byly uvedeny aktualizace pro Inventor 2020.1, 2019.4 a 2018.3.7. Najdete je ke stažení v Desktop App nebo na vašem účtu Autodesk Account.
Přehled oprav:
2020.1.1 Update
Add-Ins - Cable and Harness
Improved stability when opening a nailboard .idw file. INVGEN-31259
Add-Ins - Content Center
Improved stability when using with the Content Center Update tool to migrate Content Center libraries from one release to the next. INVGEN-30645
Improved performance when using the Update Tool. INVGEN-31434
Add-Ins - Tube and Pipe
Resolved issues encountered when rotating Tube & Pipe fittings. INVGEN-31615
Resolved an issue where the Enter Angle context menu entry is missing in the Tube & Pipe/Change Fitting Orientation command. INVGEN-32444
Assemblies - Weldments
Resolved an issue where browser nodes could not be renamed in weldment assemblies. INVGEN-31512
Drawings - Annotations - Text
Improved stability when working with custom dictionaries. INVGEN-32133
Drawings - Views
Resolved an issue where a detail view loses colors after deselecting Defer Update. INVGEN-30820
Graphics
Improved stability when zooming into associative DWG details. INVGEN-31326
Resolved an issue where inaccurate edges result when dragging a component and the wireframe visual style is active. INVGEN-31599
Parts
Improved stability when opening a part file. INVGEN-32527
Parts - Extrude
Improved stability when pressing the Esc key while editing an extrusion. INVGEN-30789
Parts - Fillet-Chamfer
Improved stability when working with the fillet command. INVGEN-31742
Parts - Sheet Metal
Resolved an issue with the German version of Inventor incorrectly generating an error message when editing a sheet metal part. INVGEN-30440
Translators - DWG-DXF
Resolved an issue where annotations and title block would not export with the correct scale to DWG file format. INVGEN-32535
2019.4.2 Update
Doplňky – Generátor rámových konstrukcí
Byla zlepšena stabilita při vkládání hliníkových součástí do Generátoru rámových konstrukcí. INVGEN-31647
Doplňky – Trubky a potrubí
Byla zlepšena stabilita při předefinování uzlu trubek a potrubí. INVGEN-32116
Sestavy – Vazby-Spoj-Sestava
Byl vyřešen problém, který způsoboval, že když nebyla vybrána možnost Povolit funkci Prehighlight, nebylo možné vybrat bod ukotvení spoje. INVGEN-32530
Výkresy
Byl vyřešen problém, kvůli kterému pomocí příkazu Uložit nešlo uložit soubor IDW s přílohou ve formátu PDF. INVGEN-32650
Výkresy – styly
Byl vyřešen problém, kvůli kterému se některé značky svarů vzájemně překrývaly. INVGEN-29819
Výkresy – True Connect
Byl vyřešen problém, kvůli kterému obrázek vložený do nového výkresového souboru následně uloženého ve formátu DWG nebyl zahrnut do uloženého souboru DWG. INVGEN-29828
Součásti – plech
Byl vyřešen problém, kvůli kterému se během opakovaného ohnutí použila nesprávná nepohyblivá reference v plechové součásti. INVGEN-31827
Platforma
Byl vyřešen problém, kvůli kterému se prvky uživatelských iSoučástí negenerovaly pomocí knihovny libxl. INVGEN-32528
Převodníky
Byl vyřešen problém, kvůli kterému se písmo čárového kódu neexportovalo správně do formátu PDF. INVGEN-29201
Byl vyřešen problém, kvůli kterému se poznámky a rohová razítka v souboru IDW neexportovaly do souboru DWG ve správném měřítku. INVGEN-31542
Uživatelské rozhraní
Byl vyřešen problém, kvůli kterému se nesprávně měnila velikost dialogu Kóta, což vedlo k oříznutí zobrazení části zadané hodnoty. INVGEN-31213
Doplňky – Kabely a svazky
Byla zlepšena stabilita při otevírání souboru IDW formovací desky. (INVGEN-31934)
Byla zlepšena stabilita při předefinování uzlu trubek a potrubí. (INVGEN-31840)
Nemůžete vytvářet nová témata v tomto fóru Nemůžete odpovídat na témata v tomto fóru Nemůžete vymazávat vaše příspěvky v tomto fóru Nemůžete upravovat vaše příspěvky v tomto fóru Nemůžete vytvářet ankety v tomto fóru Nemůžete hlasovat v anketách v tomto fóru
