Katalog CAD bloků
Téma uzavřenoUpdate Plant 3D 2018.2
Bodů: 22262
Přímý odkaz na tuto zprávu Téma: Update Plant 3D 2018.2
    Zasláno: 25.zář.2019 v 05:46
Byl vydán update AutoCAD Plant 3D 2018.2. Předplatitelé mají k dispozici inovovanou verzi potrubní aplikace Plant 3D 2018 s těmito vylepšeními a opravami - ke stažení je v Desktop App nebo na Autodesk Account:
Collaboration Workflow
  • Fixed an issue where opening collaboration projects failed in some special network settings.
  • Collaboration workflow now detects system proxy settings correctly.
  • New projects are now created correctly from a collaboration project template.
  • Performance improvements for opening collaboration projects and drawings.
Vault Workflow
  • Fixed an issue where migrating vault projects from a 2016 version failed in certain cases.
  • Duplicate vault projects were shown in the open dialog in some cases.
  • Performance improvements for opening vault projects and drawings.
P&ID
  • P&ID Symbol blocks can now be edited via project setup for non-English versions.
  • From/To properties now show correct values in the properties palette when connecting a line with a reducer.
Piping
  • Piping fittings can now be connected to lap end flanges correctly.
  • Elbows can now rotate correctly with slope.
Isometrics
  • Makeup length can now be added to bill of materials and cut piece list correctly for spool drawings.
  • Makeup length is now added to pipe dimension for spool drawings. To turn this off, set "AddMakeupLengthForSpool=false" in Dimensions settings of Isoconfig.xml.
  • Fixed an issue where the PCF export failed in certain conditions.
Spec Editor
  • The removed part can now be restored in spec.
  • Bolt length is now updated in the catalog.
Report Creator
  • DevExpress has been updated to a newer version, which includes multiple function improvements.
  • Report creator now works on Windows 10 version 1709 and later.
Tip 12067:Po instalaci AutoCAD Plant 3D 2019 zmizí některé parametry v paletě vlastností.
Tip 12130:Při zarovnání textu v buňce reportu dojde k zamrznutí Report Creatoru.
Tip 11730:Příkaz „Compress database“ zmizel z menu Plant3D 2018.
Tip 12030:Jak spustit AutoCAD pro Mac OS 10.14 Mojave?
Tip 11552:3D model v AutoCAD Plant 3D se chybně zobrazuje
Tip 11827:Při nastavení projektu Plant 3D na "Spec driven project" dojde k pádu programu.
Stránka byla vygenerována za 0,461 sekund.
