  <title>CAD Forum discussion (EN) : Mass Properties in BOM</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Mass Properties in BOM]]></description>
  <pubDate>Sat, 04 Jul 2026 00:45:18 +0000</pubDate>
  <lastBuildDate>Thu, 10 May 2012 01:17:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7788</WebWizForums:feedURL>
   <title><![CDATA[Mass Properties in BOM : I am using Mechanical Desktop...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7788&amp;PID=20118&amp;title=mass-properties-in-bom#20118</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277523">Edscad</a><br /><strong>Subject:</strong> 7788<br /><strong>Posted:</strong> 10.May.2012 at 01:17<br /><br /><P style="MARGIN: 0in 0in 0pt" =Ms&#111;normal><FONT color=#000000 size=3 face="Times New Roman">I am using Mechanical Desktop 2005.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>When I go to “Assembly”, “Analyst”, “Mass Properties”, and add a material to my parts:<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>When I click “Calculate” on the “Results” tab, the “Mass” is correct.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>However, when I insert my BOM on to my title block in Layout, the “Mass” column always shows “1.000”.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>It never shows what is shone “Results” under “Assembly Mass Properties”.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Is this an error in the program, or is there a variable I need to change?<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Thank you for your replies!!!!</FONT></P>]]>
   <pubDate>Thu, 10 May 2012 01:17:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7788&amp;PID=20118&amp;title=mass-properties-in-bom#20118</guid>
