  <title>CAD Forum discussion (EN) : Batch Drawings and Layouts Manipulation</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Batch Drawings and Layouts Manipulation]]></description>
  <pubDate>Tue, 09 Jun 2026 20:39:40 +0000</pubDate>
  <lastBuildDate>Fri, 11 May 2012 12:58:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7794</WebWizForums:feedURL>
   <title><![CDATA[Batch Drawings and Layouts Manipulation :  You can find many, many custom...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20144&amp;title=batch-drawings-and-layouts-manipulation#20144</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7794<br /><strong>Posted:</strong> 11.May.2012 at 12:58<br /><br />You can find many, many custom lisp routines with a simple search of the Internet.&nbsp; I'm sure a handful of them will do what you want.&nbsp; Find one you like, test it, then incorporate it in your script file.<br><br>I recommend using ScriptWriter by Lee Mac which can be found here...<br><br>http://www.lee-mac.com/scriptwriter.html<br><span style="font-size:10px"><br /><br />Edited by John Connor - 11.May.2012 at 13:00</span>]]>
   <pubDate>Fri, 11 May 2012 12:58:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20144&amp;title=batch-drawings-and-layouts-manipulation#20144</guid>
   <title><![CDATA[Batch Drawings and Layouts Manipulation : So far I do know that script can...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20143&amp;title=batch-drawings-and-layouts-manipulation#20143</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277945">strawhats</a><br /><strong>Subject:</strong> 7794<br /><strong>Posted:</strong> 11.May.2012 at 12:54<br /><br />So far I do know that script can be used with an application called script pro and others to execute the contents of the script (be it a series of commands or lisp) to all drawings in a specific folder. <br><br>I want a lisp that can change color of texts and dimension and extension lines in all the different dimension styles in a drawings and do so in all other drawings in a specific folder. <br><br>I am interesting to know the elements of writing such a lisp due to the fact that shop drawings means many drawings with many comment elements between them and an error means correction into multiple drawings. <br><br>Thanks in advance for your help.<br><br><br><br>]]>
   <pubDate>Fri, 11 May 2012 12:54:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20143&amp;title=batch-drawings-and-layouts-manipulation#20143</guid>
   <title><![CDATA[Batch Drawings and Layouts Manipulation : If you are trying to make changes...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20142&amp;title=batch-drawings-and-layouts-manipulation#20142</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7794<br /><strong>Posted:</strong> 11.May.2012 at 12:11<br /><br />If you are trying to make changes to a number of drawings contained with a specific folder then I would suggest looking into the use of a script to batch process all the drawings.&nbsp; Batch files can contain lisp routines too or at least I think they can.]]>
   <pubDate>Fri, 11 May 2012 12:11:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20142&amp;title=batch-drawings-and-layouts-manipulation#20142</guid>
   <title><![CDATA[Batch Drawings and Layouts Manipulation : Hi,I am looking for ways to carry...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20141&amp;title=batch-drawings-and-layouts-manipulation#20141</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277945">strawhats</a><br /><strong>Subject:</strong> 7794<br /><strong>Posted:</strong> 11.May.2012 at 07:41<br /><br />Hi,<br><br>I am looking for ways to carry lisp operations to all viewports, all dimension styles and to all dwg files in a specified folder.&nbsp; All notes or guidelines will be most welcomed. <br><br>Thanks in advanced, <br><br>Regards, <br><br>Nicolas<br><br>]]>
   <pubDate>Fri, 11 May 2012 07:41:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7794&amp;PID=20141&amp;title=batch-drawings-and-layouts-manipulation#20141</guid>
