  <title>CAD Forum discussion (EN) : autocad 2013 animation</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : autocad 2013 animation]]></description>
  <pubDate>Fri, 03 Jul 2026 03:28:59 +0000</pubDate>
  <lastBuildDate>Mon, 25 Jun 2012 20:58:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8019</WebWizForums:feedURL>
   <title><![CDATA[autocad 2013 animation : It would have helped if you had...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20665&amp;title=autocad-2013-animation#20665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8019<br /><strong>Posted:</strong> 25.Jun.2012 at 20:58<br /><br />It would have helped if you had said you were on a Mac to begin with.&nbsp; Lots of messages make respondents guess at answers to questions like yours.<DIV>&nbsp;</DIV><DIV>The simple answer is however that AutoCAD on the Mac platform is still only a couple of years old, where users have been doing professional work with it on MS-DOS and later Windows systems since about 1982.&nbsp; It's still quite a different program on a Mac, and you should expect it&nbsp;will take the programmers several more versions before they&nbsp;fully port all features over to the Apple system.&nbsp;&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>If I were to make a guess I'd speculate that the&nbsp;AutoCAD Mac user base will never surpass the numbers of people running it on Windows systems. </DIV><DIV>&nbsp;</DIV><DIV>Dave.</DIV>]]>
   <pubDate>Mon, 25 Jun 2012 20:58:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20665&amp;title=autocad-2013-animation#20665</guid>
   <title><![CDATA[autocad 2013 animation : i just found the reason why i...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20652&amp;title=autocad-2013-animation#20652</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=288859">unknowncadguy</a><br /><strong>Subject:</strong> 8019<br /><strong>Posted:</strong> 23.Jun.2012 at 20:48<br /><br />i just found the reason why i can't find this option.<br>i'm using a mac and this feature is not supported in this version, only windows.<br>but why?! :(<br>]]>
   <pubDate>Sat, 23 Jun 2012 20:48:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20652&amp;title=autocad-2013-animation#20652</guid>
   <title><![CDATA[autocad 2013 animation :    heinsite wrote:You didn&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20651&amp;title=autocad-2013-animation#20651</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=288859">unknowncadguy</a><br /><strong>Subject:</strong> 8019<br /><strong>Posted:</strong> 23.Jun.2012 at 17:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by heinsite" alt="Originally posted by heinsite" style="vertical-align: text-bottom;" /> <strong>heinsite wrote:</strong><br /><br />You didn't search the AutoCAD Help file quite enough.&nbsp; Search the Help file further using the word "animate".&nbsp; It's all there waiting for you.<br><br>Animations are set up from the 3D Modelling workspace via the Animations panel.&nbsp; You'll need to add it, it isn't available by default.&nbsp; <br><br>Dave.<br></td></tr></table><br><br>i tryed everything.<br>here is a picture where you can see, that there is nothing with "animation".<br>i'm using autocad 2013 for mac is there any difference in the version?<br><br>google and the autocad help talks about "anipath" and "render tab" and stuff like that. but i can't find anything about that... :/<br><br><img src="http://img72.imageshack.us/img72/2005/bildschirmfoto20120623u.png" height="500" width="800" border="0" /><br>]]>
   <pubDate>Sat, 23 Jun 2012 17:02:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20651&amp;title=autocad-2013-animation#20651</guid>
   <title><![CDATA[autocad 2013 animation : You didn&amp;#039;t search the AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20649&amp;title=autocad-2013-animation#20649</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8019<br /><strong>Posted:</strong> 23.Jun.2012 at 11:49<br /><br />You didn't search the AutoCAD Help file quite enough.&nbsp; Search the Help file further using the word "animate".&nbsp; It's all there waiting for you.<br><br>Animations are set up from the 3D Modelling workspace via the Animations panel.&nbsp; You'll need to add it, it isn't available by default.&nbsp; <br><br>Dave.<br>]]>
   <pubDate>Sat, 23 Jun 2012 11:49:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20649&amp;title=autocad-2013-animation#20649</guid>
   <title><![CDATA[autocad 2013 animation : hi guys,just looking for an answer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20648&amp;title=autocad-2013-animation#20648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=288859">unknowncadguy</a><br /><strong>Subject:</strong> 8019<br /><strong>Posted:</strong> 23.Jun.2012 at 10:46<br /><br />hi guys,<br><br>just looking for an answer for my problem.<br>i'm new in using autocad so i just trying with the 30 days version of autocad to do my first steps. it works good but i can't find the option for "animation".<br>searched already the web and commands like "anipath" or something else, doesn't work.<br><br>so my question. is it possible to do a simple camera operation on a curve?<br>if yes, how i can do this? do i need an plugin or something else?<br><br>hope you can help me out!<br><br>greetings from germany<br><br>]]>
   <pubDate>Sat, 23 Jun 2012 10:46:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8019&amp;PID=20648&amp;title=autocad-2013-animation#20648</guid>
