  <title>CAD Forum discussion (EN) : embossing text on sphere</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : embossing text on sphere]]></description>
  <pubDate>Tue, 09 Jun 2026 14:20:45 +0000</pubDate>
  <lastBuildDate>Fri, 03 Aug 2012 18:46:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8180</WebWizForums:feedURL>
   <title><![CDATA[embossing text on sphere : Please see my final solution a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21090&amp;title=embossing-text-on-sphere#21090</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294266">cjjatpuresilica</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 03.Aug.2012 at 18:46<br /><br />Please see my final solution at:<br><br>http://www.cadtutor.net/forum/showthread.php?71510-Text-wrap-around-sphere-in-Inventor-2013<br><br><br>]]>
   <pubDate>Fri, 03 Aug 2012 18:46:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21090&amp;title=embossing-text-on-sphere#21090</guid>
   <title><![CDATA[embossing text on sphere : Thank you, for having struggled...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21087&amp;title=embossing-text-on-sphere#21087</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=275888">rappelzdzd</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 03.Aug.2012 at 04:10<br /><br /><font size="2">Thank you, for having struggled with this for over a day I re-attempted the procedure as per JD Mather's kind but previously mis-understood advice and succeeded.</font>]]>
   <pubDate>Fri, 03 Aug 2012 04:10:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21087&amp;title=embossing-text-on-sphere#21087</guid>
   <title><![CDATA[embossing text on sphere : I thought I had resolved it but...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21074&amp;title=embossing-text-on-sphere#21074</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294266">cjjatpuresilica</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 01.Aug.2012 at 18:30<br /><br /><big>I thought I had resolved it but sadly only in part. <br><br>If I try a simple rectangular sketch profile of greater length than my desired text, it has no problem wrapping around my sphere and cutting to my inner offset surface. However if I try a Text sketch, albeit shorter I repeatedly receive the following warning: <br>  <br>"The attempted operation did not find any intersection between the Toolbody and the selected 'To' termination face/plane. Change the termination definition or the feature (profile) position."</big><big><br>  <br>If I delete say half of the text, it has no problem. I have even tried sneeking up on it by modifying the sketch after it has successfully extrude-cut. But sadly it still fails. It is as if Inventor cannot cope with the complexity of the text. </big><big><br>  <br>I have even tried extruding the text in 2 bites but once again, I receive the same error warning when I try to extrude-cut the second half.</big><big><br>  <br>Does anyone have a possible solution please?</big><big><br>  <br>Thank you.</big><br><br><span style="font-size:10px"><br /><br />Edited by cjjatpuresilica - 01.Aug.2012 at 20:08</span>]]>
   <pubDate>Wed, 01 Aug 2012 18:30:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21074&amp;title=embossing-text-on-sphere#21074</guid>
   <title><![CDATA[embossing text on sphere : Yep, sometimes you have to step...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21073&amp;title=embossing-text-on-sphere#21073</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 01.Aug.2012 at 18:18<br /><br />Yep, sometimes you have to step away, think, go back, and re-read.&nbsp; Then it all makes sense.]]>
   <pubDate>Wed, 01 Aug 2012 18:18:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21073&amp;title=embossing-text-on-sphere#21073</guid>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21068&amp;title=embossing-text-on-sphere#21068</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294266">cjjatpuresilica</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 31.Jul.2012 at 20:19<br /><br /><font size="2">Thank you, for having struggled with this for over a day I re-attempted the procedure as per JD Mather's kind but previously mis-understood advice and succeeded. In the end it was so simple I am astonished that it is not a standard Inventor feature with a distance setting for the inner offset surface that is required to extrude-cut to.<br>  <br>For those that might struggle ahead of me, I created a surface offset inwards of 0.5mm of my sphere, i.e. the depth of my required cut. I then made my solid sphere invisible and used extrude-cut to the surface, selecting my 2D text sketch as the profile. When I revealed my solid sphere again the text had been arrayed around and cut into the surface of my sphere the required depth and perpendicular to the surface.<br><br>Anyone who does not understand the latter explanation may willing contact me as per my profile email address, on this subject.<br></font><span style="font-size:10px"><br /><br />Edited by cjjatpuresilica - 01.Aug.2012 at 17:45</span>]]>
   <pubDate>Tue, 31 Jul 2012 20:19:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21068&amp;title=embossing-text-on-sphere#21068</guid>
   <title><![CDATA[embossing text on sphere :  Did you read the whole thread...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21065&amp;title=embossing-text-on-sphere#21065</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 31.Jul.2012 at 17:29<br /><br />Did you read the whole thread or just skim it?<br><br>Here's another option:<br><br>http://www.cadtutor.net/forum/showthread.php?49055-3D-Text-on-a-model&amp;highlight=emboss<br><span style="font-size:10px"><br /><br />Edited by John Connor - 31.Jul.2012 at 17:30</span>]]>
   <pubDate>Tue, 31 Jul 2012 17:29:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21065&amp;title=embossing-text-on-sphere#21065</guid>
   <title><![CDATA[embossing text on sphere :  Thank you but the solution only...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21063&amp;title=embossing-text-on-sphere#21063</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294266">cjjatpuresilica</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 31.Jul.2012 at 15:28<br /><br />Thank you but the solution only seems to be a compromise and I am concerned that when I come to write the tool-paths for engraving/milling, I will run into inconsistent depth problems. I have found some software called Zsurf which has enabled me to create an igs file of my text, is there anyway I can wrap the igs surface onto my sphere?<br><br>As an alternative I have used text geometry to create a 2D sketch of my text and tried to project it to my sphere surface using the 3D Sketch command&nbsp; 'Project to Surface.' However when I try to select my 2D text geometry using the 'Curves' option it does not allow me to select my 2D geometry.<br><br>Although I thought this option should enable one to project geometry to a curved surface?<br><br>I am most grateful for your help<span style="font-size:10px"><br /><br />Edited by cjjatpuresilica - 31.Jul.2012 at 16:04</span>]]>
   <pubDate>Tue, 31 Jul 2012 15:28:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21063&amp;title=embossing-text-on-sphere#21063</guid>
   <title><![CDATA[embossing text on sphere : I believe the answer to your question...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21062&amp;title=embossing-text-on-sphere#21062</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 31.Jul.2012 at 13:35<br /><br />I believe the answer to your question resides within this thread...<br><br>http://www.cadtutor.net/forum/showthread.php?63875-Emboss-with-wrap-to-sphere&amp;highlight=EMBOSS<br>]]>
   <pubDate>Tue, 31 Jul 2012 13:35:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21062&amp;title=embossing-text-on-sphere#21062</guid>
   <title><![CDATA[embossing text on sphere : Whilst embossing text onto a curved...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21061&amp;title=embossing-text-on-sphere#21061</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294266">cjjatpuresilica</a><br /><strong>Subject:</strong> 8180<br /><strong>Posted:</strong> 31.Jul.2012 at 13:24<br /><br />Whilst embossing text onto a curved surface such as a cylinder is straight forward, can anyone please explain how one can emboss or engrave text onto a sphere i.e. a surface curved in 2 dimensions and not just one?<br><br>Thanks.<br>]]>
   <pubDate>Tue, 31 Jul 2012 13:24:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8180&amp;PID=21061&amp;title=embossing-text-on-sphere#21061</guid>
