  <title>CAD Forum discussion (EN) : Import from cad</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : 3ds Max, Maya, VRED : Import from cad]]></description>
  <pubDate>Tue, 09 Jun 2026 21:47:17 +0000</pubDate>
  <lastBuildDate>Fri, 17 Aug 2012 09:30:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8258</WebWizForums:feedURL>
   <title><![CDATA[Import from cad : Hello, I don&amp;#039;t know about...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21257&amp;title=import-from-cad#21257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 8258<br /><strong>Posted:</strong> 17.Aug.2012 at 09:30<br /><br />Hello, I don't know about 3ds max and Maya but if you can't open DWG directly, I'd try to "save as" your DWG file in AutoCAD to a "DXF" file.<DIV>DXF means Drawing eXchange Format.</DIV><DIV>In any case, in your 3ds max or Maya look for the formats that you can open directly.</DIV><DIV>From AutoCAD to Solidworks or ProE, I use the .sat of .igs.</DIV><DIV>Please let us know how and if you have solved your problem.</DIV>]]>
   <pubDate>Fri, 17 Aug 2012 09:30:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21257&amp;title=import-from-cad#21257</guid>
   <title><![CDATA[Import from cad : Max can directly import 3D DWG...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21256&amp;title=import-from-cad#21256</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 8258<br /><strong>Posted:</strong> 17.Aug.2012 at 09:12<br /><br />Max can directly import 3D DWG files.]]>
   <pubDate>Fri, 17 Aug 2012 09:12:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21256&amp;title=import-from-cad#21256</guid>
   <title><![CDATA[Import from cad : How to import a Model make in...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21255&amp;title=import-from-cad#21255</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=278590">mirinchige</a><br /><strong>Subject:</strong> 8258<br /><strong>Posted:</strong> 17.Aug.2012 at 09:05<br /><br />How to import a Model make in auto cad.dwg files]]>
   <pubDate>Fri, 17 Aug 2012 09:05:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8258&amp;PID=21255&amp;title=import-from-cad#21255</guid>
