RSS discussions
Discussion Discussion forum
Topic ClosedAll text turns into hollow rectangles?
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: All text turns into hollow rectangles?
    Posted: 13.Jul.2012 at 20:47
No, that was not my intent.  I was just showing you an example.
<<AutoCAD 2015>>
Back to Top
Breeze104 View Drop Down
Senior Member
Senior Member
Using: Production Design Suite Premium 2015
Status: Offline
Direct Link To This Post Posted: 13.Jul.2012 at 18:46
When I got the email that someone had replied to this thread and I looked at it I thought you were making a joke for a min about the short piece of code...
Because I got about 2 pages of code....so I came here to see if what I got was actually what you wrote...LOL
Good thing I did, cuz the code here is much shorter...LOL
What I got looked like this (but 2 pages worth)....Which I am guessing wasn't your intent John...LOL
Normal 0 <w:PunctuationKerning/> false <w:IgnoreMixedContent>false</w:IgnoreMixedContent> false <w:DonotPromoteQF/> EN-US X-NONE X-NONE <w:DontGrowAutofit/> <w:DontVertAlignCellWithSp/> <w:DontBreakConstrainedForcedTables/> <w:DontVertAlignInTxbx/> MicrosoftInternetExplorer4 <w:LsdException Locked="false" Priority="0" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" Semi="false" UnhideWhenUsed="false" Qat="true" Name="ing 1"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 2"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 3"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 4"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 5"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 6"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 7"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 8"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false"
Edited by Breeze104 - 13.Jul.2012 at 18:48
Breeze
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Jul.2012 at 17:52
If the issue is related to a system variable you could handle it with a short piece of code.  Example:
(setvar “MaxHatch” 100000)
<<AutoCAD 2015>>
Back to Top
AmarARCH View Drop Down
Groupie
Groupie
Using: AutoCAD 2013 LT, Windows 7
Status: Offline
Direct Link To This Post Posted: 13.Jul.2012 at 14:37
Would you be surprised if I said "Ignorance is bliss"? Some folks wait for others to find the fix. Sure enough, I perked up and asked the question, and they come out of the woodwork with the same issue..
Would it be a factor if 80% of our office upgraded from 2000 to 2013 recently?
Since upgrading, there's been a small handful of "huh?" moments. For example, and I've yet to find a fix for this one: Why do I have to constantly turn the IMAGEFRAME to 0 each time I log into certain sheets, and, on certain sheets, the setting is already at 0 so I have to reset it to 3 then back to 0.. nuts! My best guess is there are certain settings that may be new to this upgraded experience, but we're too busy to go through a formal tutorial.
All in all, I'm loving the new CAD. But, yeah, a few head scratchers.
Edited by AmarARCH - 13.Jul.2012 at 14:44
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Jul.2012 at 16:43
Maybe it has something to do with a custom lisp routine.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 12.Jul.2012 at 14:46
The question now becomes ....Why is it affecting other computers.....if nobody changed anything????
Breeze
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Jul.2012 at 12:27
Another lucky guess.
You're welcomed.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 11.Jul.2012 at 18:16
It makes me do this: Star  THANKS!!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.Jul.2012 at 18:09
Check your QTEXT variable and make sure it is set to OFF then do a REGEN.
What happens?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 11.Jul.2012 at 17:13
I was having some fatal errors Angry so I restarted my computer and, after opening my original .dwg file, Shocked I started having the issue: each text item is a hollow rectangle from the title block (Xref) text to even the Mtext or dimensions on the sheet's details (paper & model space).
Not sure how or what started this epidemic, but it appears that a few terminals in our office have started showing this same error and was sporadically showing up on rare occassions in the past. I think the previous fix was to ignore it until it goes away. Not happenning, here.
The text will show up perfectly if I double-click on it, so I can work on it.. but you can imagine how this cannot continue. Cry
AutoCAD 2013 LT
Windows XP (mine)
Windows 7 (others)
Edited by AmarARCH - 11.Jul.2012 at 17:22
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,113 seconds.
