RSS discussions
Discussion Discussion forum
Topic Closed3D IMAGE THROUGH VIEWPORT
 Post Reply Post Reply
Author
Rogoznica View Drop Down
Newbie
Newbie
Using: AUTOCAD 2011
Status: Offline
Direct Link To This Post Topic: 3D IMAGE THROUGH VIEWPORT
    Posted: 03.Aug.2012 at 21:52
yes, once you create the viewport and scale it to whatever scale needed than simply select the viewport and lock it in the properties menu.  it should not effect it at all once other viewports are created.
are you trying to isolate one particular item on the 3d model in the viewport?
Back to Top
rappelzdzd View Drop Down
Groupie
Groupie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 03.Aug.2012 at 03:54
how poor i am!i have never seen a 3d movie so far.
Back to Top
frostfantom View Drop Down
Newbie
Newbie
Using: autocad architecture
Status: Offline
Direct Link To This Post Posted: 02.Aug.2012 at 19:55
Hey Everybody
I have a 3d object located in model space and have opened up a view port in paper space to view the object. Now I have set up everything as I want this includes several other view ports not showing the 3d object. my problem is that I can use the hide command in the view port containing the 3d object and get the image I want. However switching tabs or doing just about anything causes the 3d object in the view port to revert back to wire frame. Is there a way to lock just the one view port with hide mode on without effecting the rest of the view ports?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
