Over 1.127.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
| Author | |
NAOb
Newbie
Joined: 24.May.2012 Location: Germany Using: AutoCAD2011 Status: Offline Points: 2 |
Topic: scripts AutoCAD2011 problemPosted: 24.May.2012 at 14:08 |
Hi,
I'm trying to create a sundial (board, stick, shadow) for various locations with a script file. Coordinates are created by an Excel program and then copied into the script. When I write in the script (language is German) Three layers - board, lines & stick do exist already in the drawing: **************************************************** layer setzen lines _line 0,0,0 -22.2875183144474,321.778370435386,0 _line 0,0,0 -22.2875183144474,335.01274086895,0 _line 0,0,0 -22.2875183144474,376.256663758475,0 _line 0,0,0 -22.2875183144474,452.878332884713,0 _line 0,0,0 -22.2875183144474,582.031947045679,0 _line 0,0,0 -22.2875183144474,767.757653870612,0 _line 0,0,0 -22.2875183144474,884.034198085051,0 **************************************************** All is well, but when I start differently: **************************************************** layer setzen board _box -500,-100,-10 500,900,0 layer setzen stick _cylinder 0,-6.13672013486127,-5 3 a 0,226.439166442356,184.495269024905 layer setzen lines _line 0,0,0 -22.2875183144474,321.778370435386,0 _line 0,0,0 -22.2875183144474,335.01274086895,0 _line 0,0,0 -22.2875183144474,376.256663758475,0 _line 0,0,0 -22.2875183144474,452.878332884713,0 _line 0,0,0 -22.2875183144474,582.031947045679,0 _line 0,0,0 -22.2875183144474,767.757653870612,0 _line 0,0,0 -22.2875183144474,884.034198085051,0 ************************************************ The lines do not start from 0,0,0 as I would expect, but from a point near the stick. And the longest line does not make sense at all. Any idea where I go wrong? Regards Norbert |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 29.May.2012 at 08:36 |
Your endpoints may get "osnapped" to the existing geometry. Try to switch off osnaps (OSNAP=0).
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
NAOb
Newbie
Posted: 29.May.2012 at 09:29 |
Thanks,
it worked, even if it doesn't makes any sense. In this German installation of AutoCAD the osnap = ofang = F3 Thanks again. |
Vladimir Michl
Moderator Group
Posted: 29.May.2012 at 09:53 |
If you mean that script-generated coordinates shouldn't be influenced by OSNAP, check the OSNAPCOORD variable (should be > 0).
Post Reply
Tweet
This page was generated in 0,211 seconds.
Topic Options
