Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
Page 12> |
| Author | |
ademontis
Newbie
Joined: 02.Apr.2014 Location: Italy Using: autocad 2012 Status: Offline Points: 4 |
Topic: autolisp and browsing blockPosted: 02.Apr.2014 at 14:58 |
Hi everybody,
I have an autolisp written for Autocad 2008 on which i have used it for about 2 years without any problems... it is a lisp that browses for a block and inserts it on a pline, breaking it in the 2 contact points. The problem is... i now have loaded it on Autocad 2012 and when launched it doesn't open the 'Browse' window that normally opens when i give the command "Insert" manually. So i cannot select the block to be inserted. Any idea of what the problem could be? I attached the autolisp to the thread Thanks alot Alex |
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 02.Apr.2014 at 15:44 |
It looks to me as though you have several things commented out (with initial semicolons) that you shouldn't. The only thing not commented out that sets the 'block' variable seems to be a User selection of a Block insertion, rather than a chance to navigate to find a drawing. I think you need to relocate some leading semicolons to get the right parts of it working for you.
rs_higgins
Groupie
Joined: 03.Dec.2013 Location: United States Using: AutoCad 7-2020, SW 14, PRO-E died Status: Offline Points: 75 |
Posted: 02.Apr.2014 at 23:06 |
Not sure what you are doing with this but if you give me a step by step a I should be able to correct it.
It seem some steps are out of order and we an open parentheses. It looks like it was brought form an encrypted file that read it incorrectly. If so it may help to have that file. But here is a start just a quick clean up. uploads/427067/insbreak.lsp Edited by rs_higgins - 02.Apr.2014 at 23:12 |
dylhunter
Newbie
Joined: 25.Mar.2014 Location: China Using: AutoCAD2010 Status: Offline Points: 10 |
Posted: 03.Apr.2014 at 00:03 |
dylhunter
Newbie
Posted: 03.Apr.2014 at 00:12 |
remember to change the path "C:/public/block/" to your path.
dylhunter
Newbie
Posted: 03.Apr.2014 at 01:02 |
This program just run for horizontal and vertical lines perfectly. It's not good for diagonal line. It need be upgraded.
ademontis
Newbie
Posted: 03.Apr.2014 at 07:51 |
Thank you everyone...
the lisp used to work on autoCAD2008 with windowsXP 32bit, now we have autocad 2012 on windows7 64bit in the company i was wondering whether it could depend on that or on changes in the autolisp between the 2 version. It was a lisp i found on a autolisp forum for drafters and it seems that if i change the 'insert' commad to 'ddinsert' it opens the filedialog to look for the blocks but then it doesn't insert it. Associated to it there is a macro (sorry i forgot on the first post) that is: ^C^C_insert;\ins;\\\ Today i will try and apply your directions, hope they help. Thank you so far. Alex |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 03.Apr.2014 at 11:17 |
The fact that it doesn't work has nothing to do with whether you are running the code on a 32-bit or 64-bit machine nor does it have anything to do with the OS you are running.
<<AutoCAD 2015>> |
ademontis
Newbie
when i load it i get this message: Command: ; error: LOAD failed: "acadappp.lsp" |
John Connor
Senior Member
Posted: 03.Apr.2014 at 15:16 |
I tested the routine using 2014 and it worked. I did not get a load failed error.
<<AutoCAD 2015>> |
Post Reply
Page 12> |
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,101 seconds.
Topic Options
dylhunter wrote:
